After market Cruise control
Old Jul 2, 2019 | 11:55 PM
72442455's Avatar
Joe Ralph
Not sure if this is the correct section for this thread but ... http://www.rostra.com/universal-afte...-by-rostra.php any thoughts, feedback experiences with this? I would like to add cruise to a non existing cruise 72 vert but after some reading it sounds like factory cruise would be difficult to acquire this is the only aftermarket I’ve seen
Old Jul 3, 2019 | 05:23 AM
rickman's Avatar
I've installed the universal unit on two different vehicles. A '55 Chevy with an Ididit steering column and a '70 Chevelle with an original column. I used the 3020 control switch and ran the wire down the inside of the column. The '55 has a LS1 drivetrain so I used the VSS signal from the computer. I installed the weights on the driveshaft for the Chevelle. Both work great and no complaints from the customer. The only issue was adjusting the surge out after the install but the instructions are pretty easy to follow to make it work correctly. I plan on installing one on my '71 vert once I get it finished. Good luck!
Old Jul 3, 2019 | 05:29 AM
72442455's Avatar
Joe Ralph
Thanks for the info! This is down the road - but going to happen
Old Jul 3, 2019 | 05:31 AM
There are plenty of options for aftermarket cruise control systems:
https://www.summitracing.com/search/...Control%20Kits
Old Jul 3, 2019 | 06:43 AM
72442455's Avatar
Joe Ralph
Thanks for the link
Old Jul 3, 2019 | 07:40 AM
yellowone's Avatar
I just finished putting in a Dakota Digital cruise with the GM type turn signal lever in my 1972 Cutlass Supreme. It works great, took about a day. Would advise getting the RLY-1 relay also as mine needed it because the wiring is so bad in my car and the kit is very sensitive. The instructions were adequate but being in my late 60s it's hard to go under the dash etc. I like this cruise as it doesn't have the old vacuum actuater. just a small box under the hood.
Old Jul 3, 2019 | 08:41 AM
72442455's Avatar
Joe Ralph
Can you post a pic of your turn signal stalk plz?
Old Jul 3, 2019 | 09:01 AM
72442455's Avatar
Joe Ralph
And was it the crs 2000-3?
Old Jul 3, 2019 | 09:52 AM
yellowone's Avatar
Yes CRS2000-3 will post a pic when I can, hopefully today yet
Old Jul 3, 2019 | 10:41 AM
72442455's Avatar
Joe Ralph
Sweet! Thanks
Old Jul 3, 2019 | 10:47 AM
yellowone's Avatar
Here are the pics
Old Jul 3, 2019 | 02:12 PM
72442455's Avatar
Joe Ralph
Here are the pics
Thats awesome! Thanks for the pics - you use the drive shaft magnet set up for the computer to calculate speed?
Old Jul 4, 2019 | 04:28 PM
yellowone's Avatar
No used the cable driven pickup from the transmission speedo gear.
Old Jul 4, 2019 | 05:49 PM
72442455's Avatar
Joe Ralph
Sorry to keep blasting you with questions but does that all come with the kit? - I guess a long story short ... did your kit come with everything you need? The crs 2000-3
Old Jul 5, 2019 | 02:15 PM
yellowone's Avatar
The CRS2000-3 comes as a kit, the only extra is the relay, Part #RLY-1 which I needed for my application.
Old Jul 5, 2019 | 03:11 PM
72442455's Avatar
Joe Ralph
Thank you!
Old Jul 7, 2019 | 02:18 PM
oddball's Avatar
There's plenty of part numbers but Rostra's the only manufacturer. It's all the same junk.
Old Jul 7, 2019 | 02:26 PM
72442455's Avatar
Joe Ralph
Thanks - yeah would love an original ... but want cruise either way 😜
Old Jul 7, 2019 | 03:40 PM
bigrbandit's Avatar
72 Cutlass Ponca City OK
I just got done installing the Rostra cruise on my 72 Cutlass today. Works great, used the turn signal switch and speedo cable pulse generator. I ended up with 6000 ppm, extra low gain, 8 cyl low, sine input, NC.
Old Jul 7, 2019 | 06:16 PM
72442455's Avatar
Joe Ralph
Awesome! Thanks for the feedback!
Old Jul 8, 2019 | 10:43 AM
I installed this same stystem on my 69, zero complaints.
Old Jul 8, 2019 | 01:00 PM
72442455's Avatar
Joe Ralph
Awesome thanks!
wmachine
Sep 23, 2019 11:15 AM
scrappie
Mar 17, 2018 06:56 AM
Maverick
May 2, 2016 05:02 PM
Koda
Mar 12, 2014 08:45 PM
425HP409
Jul 13, 2011 03:03 PM
