Accessory power source
Old Aug 16, 2020 | 02:02 PM
Toms cutlass's Avatar
Old thread ... have a question related to the power accessory feed used here. It appears you connected your power feed for seats, windows, etc. to a terminal on the fuse box using a "keyed" fuse box connector. (Scott's image # 4 shows a small 'shoulder' on the red connector so it can only fit into a specific terminal on the fuse box.) Aren't power accessories that draw high power like windows, seats, conv't. top, etc. supposed to receive power through the firewall circuit breaker rated 30 or 40 amp?
Old Aug 17, 2020 | 09:53 AM
gratsoy's Avatar
This is the factory location for electric windows, including the rear tailgate window for a wagon:
Old Aug 17, 2020 | 10:08 AM
4speed455's Avatar
On my 1970 Cutlass Convertible, I have a circuit breaker on the firewall under the hood. That circuit breaker is fed direct from the battery and supplies voltage to the power window relay. The relay is activated by a pink wire that plugs into the fuse panel. So the voltage that powers the window goes from the battery through the circuit breaker and to the relay. When you turn the key on the pink wire activates the relay and allows the voltage from the circuit breaker to power the windows.
Old Aug 17, 2020 | 10:09 AM
I moved this thread out of an old Parts Wanted ad and into it's own thread, since it was not asking about parts for sale.
What you are missing in that diagram is that the terminal on the fuse box is NOT powering the high current accessories like power windows. It is simply the wire that turns the isolation relay on or off when the ignition is in the RUN position. The actual power for these accessories comes from a circuit breaker under the hood and feeds through that isolation relay to the accessory.
Old Aug 17, 2020 | 10:24 AM
gratsoy's Avatar
This sounds correct. I ended up getting the missing piece from the original car I got the power set-up from and it used the Red plug with a splitter. I assume this runs the relay but also supplies the power for the bench seat.
Weirdly I can't find wiring for electric windows in the assembly manual, unfortunately I don't have a PDF of the body manual handy at the moment.
Old Aug 17, 2020 | 10:25 AM
Thanks all for the schooling and images.
JC3Hawaii
May 26, 2019 12:13 PM
Aqua67
Nov 20, 2017 03:11 PM
rand5204
Nov 6, 2017 09:02 AM
setagus
May 10, 2014 01:09 AM
oldsconv
Mar 24, 2009 04:18 PM
