94 olds cutlass convertible
Old Feb 2, 2016 | 03:13 AM
roby wicht's Avatar
interior lights stuck on, disconnected door handle wire on door. Is there some kind of relay or switch on the door lock itself?
Old Feb 2, 2016 | 09:06 AM
CRUZN 66's Avatar
Olds Fever
Yes there is a switch on the latch itself with a two wire plug lead about 12 inches long... Did you also check the door jamb switch on the A-Pillar, as well as the dash light dimmer switch... The dimmer switch, in the full on position will keep the interior lights on...
Old Feb 2, 2016 | 10:04 AM
roby wicht's Avatar
jamb switch was the first spot I checked. Will take door panel off next. Any ideas where to find the part would be helpful. Tahnks
Old Feb 2, 2016 | 03:18 PM
CRUZN 66's Avatar
Olds Fever
IIRC, It's part of the latch... I just sold a LH door latch to an individual with a 93 Convertible, but I don't recall how exactly the switch was mounted to the latch... Worse case, just unplug the door switch, I believe the interior lights will still function with the jamb switch...
ros6872
Oct 30, 2015 09:41 AM
ros6872
Oct 31, 2014 05:04 PM
70SXchris
Feb 24, 2012 05:02 AM
70SXchris
Mar 25, 2011 09:31 PM
djsoldzparrts
May 22, 2008 12:53 AM
