74 olds can't drive at nite
Old Jun 20, 2013 | 09:55 AM
steven r's Avatar
my headlights flicker after about 20 mins of having them on . i have changed the headlight switch put a new headlight in also and cleaned the grounds but it still does it.. could some plz help me with this problem
Old Jun 20, 2013 | 05:40 PM
White_Knuckles's Avatar
Trace the circuit to see if a relay is between the the switch and the lamps. Both lamps are flickering so you're solving for what is in common to both. The ground points are usually separate, the lamps are uniquely different so you're down to the 12V supply. 20 min is a long "burn" time so you're looking for what could be arcing or getting hot after extended time. Points to a relay with a weak coil or carboned-up contacts. They chatter or internally arc causing flicker.
Old Jun 20, 2013 | 06:47 PM
Lady72nRob71's Avatar
Welcome to the site!
Need some more info to help...
Does it do this on low OR high beams?
Do they dim, or flicker, or go off for a few seconds then back on? Which do they do?
Are they stock-type bulbs or some new aftermarket "high output" kind that could draw too much current and trip the circuit breaker in the light switch?
Old Jun 20, 2013 | 06:51 PM
What Rob said.
Also, you say your "headlights" flicker, but you "put a new headlight in."
Is this one or both lights, and what made you decide to replace only one?
Lonestar
Mar 8, 2014 04:27 PM
Lonestar
Mar 5, 2014 05:26 PM
1968_Post
Jul 27, 2013 06:01 AM
ThePackRat
Sep 18, 2012 07:35 PM
bentlyf1
Jun 14, 2012 08:07 PM
