72 washer pump polarity?
Old April 17th, 2011 | 05:40 AM
garys 68's Avatar
After completely rewiring my car (72 cutlass), I found that the wiper fuse was the only one blown. I narrowed it down to the washer pump. My 2 contact plug will go in either way (pic below). Which side should the yellow power wire go to?
Old April 17th, 2011 | 06:45 AM
jensenracing77's Avatar
i would have to look at one again but i don't think it will matter. it is just a coil that is powered to create magnetism and pull the little lever to activate the washer pump.
Old April 18th, 2011 | 05:18 AM
garys 68's Avatar
Isn't there an electric pump in there? I really have no idea since the only thing I got with the car was the wiper assembly.
Old April 18th, 2011 | 06:07 AM
Lady72nRob71's Avatar
Yellow goes on the wiper motor side (towards the brake booster).
Blue is the side that gets grounded when the button is pressed.
Yes, this is not an actual pump but a solenoid that engages the wiper motor driven pump.
I have 3 GM cars with similar pumps and none of them work. I will not comment on them any further ...
Old April 18th, 2011 | 10:50 AM
garys 68's Avatar
Looks like maybe I should look for an aftermarket washer setup.
Old April 18th, 2011 | 10:55 AM
InfoJunkie's Avatar
InfoJunkie
There are o-ring kits for them available if the issue is just not pumping. .
Old April 18th, 2011 | 11:04 AM
garys 68's Avatar
If I kept the factory look to the washer pump, it would be the only factory looking thing under the hood.
Since I dont have the reservoir, tubing, spray nozles, etc. and that solenoid seems to short out the circuit, I think I'll just put in a universal one.
http://www.summitracing.com/parts/ANC-66-01/
Old April 18th, 2011 | 10:32 PM
71 Cutlass's Avatar
One of None W-31
I bought an aftermarket pump at O'reilley Auto parts 10 years ago ($28) and it still works like a charm.
April 23rd, 2013 06:16 PM
1973olds98
July 13th, 2009 04:47 PM
Chumley
June 19th, 2008 07:36 AM
bjtstarfire
January 24th, 2008 10:42 AM
Big Joe P
April 15th, 2007 04:05 PM
Quick Reply: 72 washer pump polarity?
