72 Supreme Signal, lights not working
Old Nov 20, 2009 | 01:25 PM
meraul's Avatar
I have a 72 cutlass supreme and the signal lights have just started to blow the fuse.The four way flashers work and the lights all work. Could I have a short in the signal light wiring in the steering column?
Any ideas before I buy a new wiring harness.
thanks
Old Nov 20, 2009 | 05:45 PM
a6m5zerosen's Avatar
1977 Cutlass Supreme
It is a possibility that the wiring in the column is at fault, but it is by no means the only possibility. The wiring for the turn signal switch is part of the switch, & if you buy a new switch, you're buying new wiring from the switch to the connector on top of the lower steering column. As a quick check, you can plug a new switch (or good used switch) into the column wiring connector under the dash & actuate it -see if you still have the problem. If the problem disappears, the problem is the switch in the column.
costpenn
Jun 24, 2015 10:38 PM
Herv Purcell
Aug 31, 2014 02:22 PM
Classicarcrazy
Jul 15, 2012 05:34 PM
1badcut
Feb 13, 2011 06:27 PM
cbogartjr
Aug 3, 2008 06:18 AM
