72 Olds alt hook-up question
I pulled the alt off the '72 Olds Cutlass I am doing for a friend and the plug in wires came out. I am trying to figure out which goes where. One is field and the other is senser according to the minimal manual I have on hand. The brown wire is supposed to be the field wire I know but the alt is not marked. It should have a '1' and '2' from what I see. The terminal I believe to be '1' shows continuity to ground and the other has no continuity there. Which would be the field?????? Will I damage it if I guess wrong ?
I just finally figured out how to start a new thread. My problem is that on the 72 Olds Cutlass I am working on I removed the alt and wiring and the connectors were bad and came out of the plastic two prong plug. I have a minimal diagram that says the brown wire is the field wire and the red one is the sensor. I have a brown wire and a blue wire. The alt is not marked, at least not well enough for me to see. I believe a '1' would be the field connection. The top connection reads continuity to ground and the other does not. Which should be the field? And will I damage it if I guess wrong? Here's a picture of it now with the brown wire on the top, grounded, connector.
I do believe I have it backwards from some old photos I just found. I threw in some extra photos of the project too.
olddaz
Aug 27, 2014 06:39 PM
Blake Willoughby
Mar 11, 2012 01:04 PM
