'72 Delta 88 no brake lights/hazard lights
hey guys,
1972 Oldsmobile delta 88 convertible 350
took the Olds out of winter storage yesterday. after the coil failed back fired and blew the muffler out. today we changed the coil, fuel filter and some vacuum line she runs great! after we got it all buttoned up i figured out the hazard lights and brake lights do NOT work.
weird part is they will work if you turn on a turn signal..
so bulbs are good, grounds are good, brake switch is good, fuses are good.
at this point i'm 99% sure its the turn signal switch. i have brake light power going into the switch but NO power coming back out to the left or right brake light.
am i on the right track? i'm pretty sure after all my testing i have it pin-pointed. i then need to figure out what all is involved to replace the switch..from what i have gathered it involves removing the steering wheel..any other info to be had?
thanks guys!
thanks guys!
i have wiggled,juggled and played with the switch,hazards and the harness running to it and no dice. its actually worse now the left signal will not work. i suppose after 42 years and almost 90k miles of use the switch is just toast.
Depending on year and options, you can usually get the switch at your local auto parts store for a reasonable price, or someone on here may have one to sell (though with shipping it may not be any cheaper).
i've found them online all over the place, i'll order one tonight and hopefully have it within a few days. i really don't feel like pulling the wheel though
gotta do what ya gotta do i suppose.
Most parts places around here rent a steering wheel puller & refund your money when you bring it back. I don't know if they have the same policy where you are? They are really pretty easy to remove & the switch should fairly easy also.
Good luck.
Good luck.
