72 cutlass turn signal ground help!
Old Mar 21, 2012 | 11:34 AM
beauty in primer's Avatar
I've got a '72 cutlass s thats been an on and off resto project for nearly 20 yrs. My aunt started it and then stopped doing anything with it. i've been working on it the last couple of yrs now.
My biggest issue right now is with the turn signals. The left side works fine but the right side flashes fast with the lights off and stays on with the lights on and both rear corner lamps flash dimly with the right side.
I'm looking for the grounds but cant find any. If anyone could help out with this, it would be greatly appreciated.
Old Mar 21, 2012 | 01:35 PM
Eldomiwok's Avatar
Sorry I suck at electrical but my 72 supreme blinker is real wobbly loose an sometimes it makes my horn honk when I turn. Ask your question again reword it someone has your answer
Old Mar 21, 2012 | 02:46 PM
Highwayman's Avatar
Originally Posted by beauty in primer
...I'm looking for the grounds but cant find any...
This right here.. "the right side flashes fast with the lights off and stays on with the lights on and both rear corner lamps flash dimly with the right side." has bad ground written all over it.
Old Mar 21, 2012 | 06:53 PM
Lady72nRob71's Avatar
I am almost thinking the sockets are metal and they ground right to the tail light housings which ground to the bumper, then to the frame. Is the inside of the socket clean? That is a common issue.
Old Mar 22, 2012 | 07:08 AM
it turns out its actually both side that are not working correctly but the hazards work just fine so i'm going to change out all the bulbs and the t/s flasher
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
JPMDaddy
Oct 20, 2013 08:21 AM
ctrain22
Nov 6, 2009 05:53 PM
martine
Jan 22, 2009 01:13 PM
