72 CS starting problems...
Old Dec 27, 2018 | 12:59 PM
Bmoskal's Avatar
My 72 CS isn't wanting to start, I get nothing from starter so I took it off and had it tested at local auto parts store and it passed. So I'm trying to figure out what's wrong now that thw starter is fine. I tried starting the car in neutral and did nothing. My cables are tight on the battery posts with a charged battery also... What should I look at next?
Old Dec 27, 2018 | 01:29 PM
I would look at the neutral safety starter switch on the bottom of the steering column. Make sure its in park/neutral. jumper the 2 purple wires and turn the key.
Old Dec 28, 2018 | 06:12 AM
The wiring diagram for your car.
Do that and you'll see the purple wire that runs from the "S" terminal on the starter solenoid through the firewall connector to the neutral safety switch to the ignition switch and from there to power. Figure out where in that circuit power is interrupted and fix it. Problem solved.
txtom
Apr 26, 2017 09:24 AM
teqdave
Nov 21, 2013 03:29 PM
Gixxere
Aug 23, 2011 10:37 AM
Daniel2008
Jan 1, 2009 07:43 PM
1973_442
Jun 13, 2007 09:22 AM
