72 442 Ignition Issues
Old Sep 4, 2018 | 12:47 PM
k-rob's Avatar
Maybe someone can help me out here. I have a 72 442 with an odd starting or electrical condition. It has a 455 motor in it. I haven't started it up for about a month, so I went to fire it up the other day and discovered something very odd. When I opened up the door, my interior lights came on as they should. I put the key in the ignition and went to start the car. When I turned the key to the start position, I got one click from the starter and everything went dead. No interior lights, horn, nothing. The whole car was dead. After a while, I came back to try again. The same thing happened. Periodically, I get power to the car, and sometimes I get nothing. When I do have power, I lose it as soon as I hit the start position with the key. I have taken the starter off, and it has passed a bench test. The solenoid checks out as well as the starter motor. I re-installed it and continue to have the same issue. I have a little over 12v when I check the battery. The connection from the battery reads the same, but when I check the voltage at the junction block, I get nothing. I have visually inspected the wire from the solenoid to the junction block, and I see no obvious issues. No burns through the wire, the ends appear to be attached very well, etc. Maybe the wire is fried on the inside but not visible from the outside? It's a very odd problem to me, but maybe it's as simple as replacing that wire. If anyone has other ideas as to what it might be, I would sure be interested to hear them.
Old Sep 4, 2018 | 01:22 PM
72455442RA's Avatar
Hello
and welcome
start with cleaning the battery cable connections at the battery
original ends at the battery or aftermarket bolt on ends ??
pictures are usually required on first post ,,,, so we know your not a robot ...
just kidding
Scott
zooom zooooom
Just over 12V is a very weak battery. I'd charge it and see what happens next. Or you could jumper the battery and try starting it. If the car starts you can probably look for a new battery.
Old Sep 4, 2018 | 02:37 PM
k-rob's Avatar
Thanks, guys. The battery is only abut a year old, but maybe I got a lemon. I have cleaned the battery posts and cable connections, and I did have the charger on it for about 12 hours. I will try to jump it to see if that is the ticket. I am just baffled as to why I get no voltage at the junction block when I have 12+ volts at the battery. The junction block is a direct live feed from the same post on the solenoid that the battery cable is hooked to. Scott, here is a pic.
Old Sep 4, 2018 | 02:40 PM
k-rob's Avatar
I forgot to mention........the negative cable is original, but the positive is aftermarket bolt on end.
Old Sep 4, 2018 | 03:06 PM
The condition you described is typical when there is a very resistive connection; I have experienced this many times with either a loose or corroded connection at one of the battery terminals. When the key is turned to the start position, the high current to the starter tries to flow though the resistive connection and "blows it open" so to speak. I would suggest removing the cables from the battery and making resistance measurements to see if/where the high resistance is.
edit:
Just saw your post about the bolt on end - those have given me lots of issues over the years. Take it off and clean it up. Soak the cable end and terminal in a baking soda/water solution, then ensure the bolts are tightened well when reinstalling. That may fix your problem.
Old Sep 4, 2018 | 03:14 PM
k-rob's Avatar
Thanks, Kenneth. After removing the battery cables, where should I check for the resistance?
Old Sep 4, 2018 | 03:20 PM
Buy a new battery cable. The battery needs to be charged to 12.6v (the .6 is very important).
Old Sep 4, 2018 | 03:35 PM
72455442RA's Avatar
did you
did you take the clamp off and clean there also ??
replacing mine on my dually gmc today the POS cracked .....at the neck
started crankin over slow
yup
Old Sep 4, 2018 | 03:54 PM
^^^THIS! Your connections have corroded. They were able to carry the small current needed to illuminate the dome light, but as soon as you tried to crank the starter, the high current draw caused this resistive connection at the battery terminal to arc, which pretty much opened the circuit. Clean both battery terminals and cables and make sure the battery is fully charged. This is very common in situations like this.
Old Sep 5, 2018 | 05:29 AM
k-rob's Avatar
Y'all were on the money. I took the aftermarket cable end off and cleaned it up and things worked as they should. I had visually inspected it before and it appeared to be clean, but I guess not. Don't judge a book by it's cover, huh? Thanks for the advice!
lmarquette
21
Jul 24, 2021 02:03 PM
Cutlass455
Jun 12, 2018 11:31 AM
lshlsh2
Feb 8, 2015 01:01 PM
LoganMiller68
Jun 2, 2014 07:25 PM
olds88royalvert
Apr 27, 2014 08:42 AM
