71 Supreme Convertible Top Problem
Old Oct 4, 2007 | 01:01 PM
Sturgeon's Avatar
71 Cutlass Supreme
I have what appears to be an intermittent problem with the movement of the convertible top in my 71 Cutlass Supreme... sometimes it works fine, sometimes it stops moving and then will continue after I let it rest for a minute or so, sometimes it stops moving totally (until I come back to it the next day). I replaced the original switch with a high capacity plow toggle... the original switch was getting very hot, then stopped working completely (too expensive to keep changing out).
Anyone have any ideas what might be going on... ground problem? Is there some kind of relay in the line that is resetting after some period of time?
Old Oct 19, 2007 | 02:10 PM
CHRISH8846's Avatar
There is a circuit breaker on the firewall behind the brake booster.Sounds
like the top motor is overheating and casuing the breaker to pop and then reset after awhile. I had to replace my breaker last year and had to put a 40 amp one in, so that tells you the motor draws alot when it's working ok,and I'm sure that is the reason your switch was getting so hot.
Old Oct 19, 2007 | 04:13 PM
Are you sure the hydraulic reservoir is full?
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
bigfun64mo
May 18, 2015 07:28 AM
kens69olds
Jul 19, 2011 09:22 AM
cjprm
May 19, 2011 09:17 AM
Olds luvr
Dec 2, 2010 08:26 AM
