71 442 Alternator Fan
Old Feb 3, 2012 | 01:51 PM
Rocketbrian's Avatar
Why does the fan on my alternator have inconsistent blade shapes? Any ideas? Noise?
Also, the fan has a notch cut out signifying it must go on the shaft one way only, however, there is no corresponding key on the shaft for it to line up with. The shaft is perfectly round. Any ideas?. Thanks.
Old Feb 3, 2012 | 01:55 PM
The variable spacing is almost certainly done to avoid an acoustic resonance at a specific RPM. The notch is likely used for tooling during fabrication to orient the part. I'm guessing that they cut out a blank first then stamp the vanes, so clocking during that operation is important.
convertible 63
May 9, 2018 06:10 AM
442mark
Sep 30, 2017 01:06 PM
KZ442
Nov 9, 2010 05:01 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
