70 olds alt. idiot light
Old Apr 23, 2018 | 04:45 PM
l69gm's Avatar
My alt. light stays on when the car is idiling.When i bring the r.p.m up,the light goes out.The alt.is charging though.Anyone have a idea why it does that?Ground problem?Thanks.
Old Apr 23, 2018 | 05:12 PM
The alternator may not be charging sufficiently, as in there may be a leaky diode. I had that issue on my car back in the 90s.
I guess I should ask what type of alternator setup you have: factory setup or some sort of retrofit?
Old Apr 23, 2018 | 05:25 PM
l69gm's Avatar
Its the factory set-up.All stock.
Old Apr 23, 2018 | 05:35 PM
cherokeepeople's Avatar
it could be charging fine and have a bad diode.
Old Apr 23, 2018 | 06:03 PM
Gerald Nickels's Avatar
Take your alt. to a auto parts store and get it checked.
Old Apr 23, 2018 | 06:08 PM
Is it an internal or external voltage regulator?
Old Apr 24, 2018 | 01:28 AM
l69gm's Avatar
It has the internal voltage regulator.
Old Apr 24, 2018 | 05:06 AM
Then yes, get the alternator checked.
Old Apr 24, 2018 | 08:07 AM
stellar's Avatar
stellar
Is the belt tight?
Old Apr 24, 2018 | 04:01 PM
l69gm's Avatar
Yes,Belt is tight.Thanks for the info.everyone.
bobfo1
Jun 14, 2012 06:15 PM
Gary's 2 442-S
Jun 5, 2012 10:31 AM
EastLansing
Dec 6, 2011 07:18 AM
ej69
Jul 21, 2010 04:48 PM
Gaz Hog
May 11, 2008 02:47 PM
