70 Cutlass radio wire diagram
I'm in the process of swapping out the original factory am radio with a Custom Autosound replacement. Does anyone know what the original factory radio wire colors are? Looks like a fairly easy job, just don't want to fry the radio.
Yellow was the 12V switched feed, grey is the light feed, blue would be rear speaker + and cannot remember the front speaker + color (it should be the only wire left).
Note the original speakers had their - terminals grounded so make sure your radio can handle this. If it cannot, you would need to rewire the speakers to avoid radio damage. If you do that, new speakers with proper impedance would probably be best.
bsambo59
August 13th, 2013 06:47 AM
