'70 Convertible SX blows fuse to accessory light harness
Old Apr 20, 2017 | 03:05 AM
mcalvo's Avatar
Just replaced main dash harness is a '70 Cutlass SX. Headlights, wipers, top etc. all work and car will start. Courtesy lights come on when door opens as well. Then when I connect accessory harness (plugs into main harness and has a single ground) once that is connected and it's two metal light sockets are snapped into the lower metal dash, if they have bulbs, when either door is opened the fuse to the accessory circuit blows.
I tested the metal sockets and there are two wires; orange and white. Orange is hot all the time and the white grounds when the doors are opened.
Any ideas on what could be going on?
Thanks,
Michael
Old Apr 20, 2017 | 03:16 AM
You have a short somewhere in that harness.
Old Apr 20, 2017 | 03:19 AM
mcalvo's Avatar
Which harness, the main or accessory? I've actually tried two accessory harnesses with the same result. So I am thinking the issue is with the main harness but it's brand new from Fusick and am not looking forward to finding a short in it :-(
-Michael
Old Apr 20, 2017 | 04:35 AM
The orange wire as you said is a constant non-switched 12v supply. The white wire is connected to the door jamb pin switch circuit. Are those the only 2 wires in the harness?
Old Apr 20, 2017 | 05:06 AM
mcalvo's Avatar
Worth noting is the dash harness that I removed from the car used the spaded door jam switches that only have a single wire. The new harness from Fusick used a pin style door jam switch that has 3 wires going to drivers door (black, white and white with black stripe) and 2 going to passenger side (white, white and black stripe).
-Michael
Old Apr 20, 2017 | 07:57 AM
mcalvo's Avatar
Digging into the schematics, the new main harness looks correct. The 3 wires on LH jamb switch are black for Door Key Buzzer (which works), a white and white w/black stripe.
Black goes to key buzzer
white goes to main light switch, LH and RH jamb switches and dome/opera lights (work when door opens)
White/black stripe goes to LH and RH jamb switches, courtesy and map lights (the courtesy circuit is the one that blows the fuse)
The fuse blows when the door opens and when that happens the white and black, using my Power Probe, goes to ground.
Old Apr 20, 2017 | 09:21 AM
Ohming a light circuit to ground won't work as the remaining laps will indicate a short.
If every thing works without the harness plugged in with no fuse blowing then the issue is withing the harness or how you hooked it up. Make sure the wires on the light socket that I'm assuming bolts to ground are not reversed enabling the hot to short to ground when you bolt them in place.
Old Apr 22, 2017 | 10:11 AM
mcalvo's Avatar
In the end it was a due to a single contact bulb being used in a dual contact socket.
-Michael
Old Apr 22, 2017 | 02:40 PM
Which light was it?
Old Apr 22, 2017 | 05:40 PM
Wow, the singles usually won't plug into a dual socket.
Old Apr 22, 2017 | 06:02 PM
Yeah, the lugs have different depths on one and the same depth on the other to prevent insertion into the wrong socket.
rothlane'68
Jan 29, 2017 07:34 AM
ankerclanker
Oct 30, 2016 10:17 AM
Oldscutty72
Dec 28, 2015 01:56 PM
Colpage1
Jun 22, 2015 08:19 PM
