'70 442 Steering Assembly
Old Aug 23, 2014 | 06:39 PM
DRXOLDS's Avatar
Hello,
Putting new tilt steering/column set-up in the OLDS. At the (OEM) rag joint it has a wire that ties it in for a ground. The new rag joint has a "band/strip" similar to all the ground set-up for gauges etc...any hint's on the install ?. And yes the OEM bolt was rounded off ...but a 12mm 6 point socket bit enough to get it off.
Time on job about 2 hours ....but it is off
Thanks!
Old Aug 24, 2014 | 03:07 PM
Originally Posted by DRXOLDS
Hello,
What's the question? The strap and the wire work exactly the same to provide the ground path for the horn button. That's all they do. Just be sure whichever one you have is properly grounded on both sides of the rubber joint.
Old Aug 25, 2014 | 10:09 AM
DRXOLDS's Avatar
The question was the basic function of the wire or replacement joint that came with a band / strap type ground. Thanks for the info.!
stratoblues
Sep 1, 2014 06:52 AM
dfire25
Jan 24, 2013 10:13 AM
1965cutlassragtop
May 8, 2012 08:34 AM
Oldsmobile Iron
Oct 1, 2009 05:44 AM
droptopron
Jun 3, 2008 01:04 PM
