70 442 AT Console wiring
Howdy, putting my 70 442 HT back together after quite some time - not sure how to reconnect the wiring harness that goes under the console. Has 2 sockets a wire with a loop at the end (ground??) a black plug, the 4 prong plug and the flat plug with abt 6 pins in her. Any guidence would be GREATLY appreciated. Thank you!
console wiring
I converted my 70 Supreme from column to console shift about a year ago. According to the shop manual, you're correct, the end loop is the ground that goes to shifter assembly screwed in underneath the neutral switch. the 2 plug in leads closest to that go to neutral switch. Sometimes on these the neutral switch is still on base of column. If you don't have neutral swith on shifter, don't use those leads. At the complete other end, that plugs into console lead in dash, somewhere around the radio. There should be 2 light sockets, 1 at another end close to a pressure switch and the other just in line 2/3 down harness. First is for courtesy lamp at base end of console, the other for shift indicator lamp.
October 14th, 2013 06:57 AM
oldzy
September 10th, 2009 05:23 AM
