70 442 AT Console wiring
Old Jul 20, 2011 | 06:00 PM
dhoopty's Avatar
Howdy, putting my 70 442 HT back together after quite some time - not sure how to reconnect the wiring harness that goes under the console. Has 2 sockets a wire with a loop at the end (ground??) a black plug, the 4 prong plug and the flat plug with abt 6 pins in her. Any guidence would be GREATLY appreciated. Thank you!
Old Jul 23, 2011 | 10:28 AM
kips70cutty's Avatar
console wiring
I converted my 70 Supreme from column to console shift about a year ago. According to the shop manual, you're correct, the end loop is the ground that goes to shifter assembly screwed in underneath the neutral switch. the 2 plug in leads closest to that go to neutral switch. Sometimes on these the neutral switch is still on base of column. If you don't have neutral swith on shifter, don't use those leads. At the complete other end, that plugs into console lead in dash, somewhere around the radio. There should be 2 light sockets, 1 at another end close to a pressure switch and the other just in line 2/3 down harness. First is for courtesy lamp at base end of console, the other for shift indicator lamp.
98 man
Dec 18, 2014 10:14 AM
Oct 14, 2013 06:57 AM
98form
Sep 9, 2013 09:32 AM
todd66442
Oct 17, 2009 07:00 AM
