70-2 console light switch?
Old Dec 5, 2010 | 05:07 PM
jensenracing77's Avatar
i did not see any reproduction of these switches anywhere. what do people do for them. i have not looked but will a door jamb switch work?
Old Dec 31, 2010 | 09:37 AM
mv213's Avatar
Classic GM Fan
Do-able, maybe not easy
Hi there! I'm surprised you haven't had an answer yet....anyways, a door jamb switch only has one lead because the switch body itself is grounded by screwing into the body. You could use one, but you would have to rig a way to ground it.
You could use a ring terminal like this and a nut to hold it to the back of the switch, then run a wire to ground or tie it into the ground wire of the console harness.
Or you might get lucky and find a two-terminal switch. Maybe take the old one in to a parts place and see if they can match it.
Hope this helps...I've gotten lots of help from guys on here. Especially Rob!
tdhill01
May 8, 2015 10:49 AM
Al Sanchez
Jun 4, 2013 02:59 PM
70Post
Feb 15, 2013 06:06 AM
pcard
Jan 17, 2013 06:03 PM
