69 Cutlass S wiring troubles
Old Aug 30, 2017 | 11:35 AM
Bitburger's Avatar
I'm having a wiring issue with my 69 Cutlass S. With both the ignition switch and the light switch either on or off all four side marker lights are on very dim.
The problem began after I reinstalled the steering column. I swapped out the
turn signal assembly and still have the same problem.
Using the light switch all lights work as they should with or without the key switch on or off.
Not sure if it is related but I have no power to the radio, fuse is good.
I have rechecked the grounds to the front harness that handles the front side marker lights as well as the harness to the rear side lights.
Any trouble shooting suggestions would be appreciated
Old Aug 30, 2017 | 12:15 PM
What happens if you unplug the direction plug on the column?
Old Aug 30, 2017 | 01:12 PM
Bitburger's Avatar
Ok, that worked as the light went out.
The end of the turn signal harness where it attaches to the main wiring harness is in two pieces. To align the color coded matching wires I had to cut the turn signal side of the connector into two sections or the wires would not align correctly.
The main section has the following six wires. Left to right as you look up to the column where the plugs connect.
White Green Yellow Purple Brown Blue
The second section of the plug contains the following four wires:
Lt Blue Black Pink Black
When I tried the other turn signal harness it fit correctly and all the wires lined up as they should. It also kills the dim light when unplugged.
I'm guessing now that the problem is associated with one of the first six wires listed above.
I have swapped out 4 different headlight switches and in doing so found that using the light switch reo-stat I can make the dim side marker lights bright.
Old Aug 30, 2017 | 01:41 PM
Did you turn on the lights and ignition to make sure all the lights work correctly?
I do not have a schematic handy for your year car, so can't follow wire colors.
If your not finding the problem in the harness connectors, move back to the new switch. Look at where the TS arm is connected to the switch with a screw. Sometimes if its overtight it will lightly short over the wire terminals on top of the switch.
Old Aug 31, 2017 | 03:38 AM
Bitburger's Avatar
Problem is the same without even having the turn signal arm attached.
My schematic shows the brown wire is to the side markers.
Old Aug 31, 2017 | 04:25 AM
Ok, I found some diagrams. The parking light, tail light, and side marker lights are all hooked in parallel (front and rear) with power coming off the headlight switch. If the marker lights are dim, so should the parking lights?
The blinkers, 4 way power, and brake light power goes through the TS switch. The only thing that is common through the TS switch that feeds both front signal lights and rear signal lights is the 4 ways. Plug the column connector in and pull the signal stat at the fuse panel and see what happens.
Old Aug 31, 2017 | 06:55 AM
Bitburger's Avatar
Ok I'll try that, when activated the the parking lights are bright. The flashers are currently not working they light but don't flash. I think it is strange that the HL switch reostat will make the side markers bright or dim.
Thanks for the help Eric.
Brad
Old Aug 31, 2017 | 07:11 AM
Hmmmmm, plug everything back in and then unplug the headlight plg and inspect the connector and the switch. You may have to remove it from the dash to get access. There is a release on the side of the switch to pull out the handle and then unscrew the nut that holds the switch to the dash and see if it will drop down. Disconnect the battery before you remove the switch.
Old Aug 31, 2017 | 07:32 PM
How did you make out?
Old Sep 2, 2017 | 06:05 AM
Bitburger's Avatar
Sorry, I was travelling and will be away for a few days and will try plugging and unplugging the HL switch when I get back. I have already swapped out four different HL switches and still the same problem.
Old Sep 2, 2017 | 07:55 AM
It may be in the plug, the curious part of your problem is it dims with the HL rheostat.
Old Sep 2, 2017 | 11:08 AM
m371961's Avatar
I don't have a diagram to look at and I may be way off base. Does the interior dome lamp on this car normally light with light switch turned full left? Is it possible the wiring for the dash lights, dome light and wiring for parking lamps is crossed at the headlight switch? Do the side lamps that are dim (switch on or off as in first post), go out when doors are closed?
Are the dash lights dimming as designed?
Just tossing this out there, I kinda like chasing electric gremlins.
Old Sep 4, 2017 | 12:32 PM
wls559's Avatar
Color Wire Diagram
In my album, I have a color wire diagram for a 68, if it helps.
Old Sep 5, 2017 | 02:45 PM
Bitburger's Avatar
Right now I am away from the problem and am at the beach prepping for Irma. I did bring my manuals with me and have been searching the wiring schematic for ideas. The car is being reassembled and the wiring harness was replaced so anything is a possibility right now.
I don't believe that the black wire coming from the horn relay (the one with the fusable link is currently connected. So that will be my first order of business when I return. I don't think the probem is in either the HL switch or the TS switch in the column.
Thanks,
Brad
Old Sep 5, 2017 | 02:53 PM
Bitburger's Avatar
Have not checked the dash lights or the kick panel interior lights, no dome ( convertible). The kick panel lights should light when the rheostat is turned all the way left (I think)
Not sure how the wires could have crossed at the HL switch as the plug I intact. One of the accessory lights may not be hooked up and could be grounding out.
I'll get back on this in a few days when I get home.
Thanks,
Brad
Old Sep 5, 2017 | 02:54 PM
Bitburger's Avatar
Thanks, I do have a service manual with a good schematic I just have very limited ability. lol
Old Sep 5, 2017 | 02:56 PM
Bitburger's Avatar
Not sure how the wires could have crossed at the HL switch as the plug is intact. One of the accessory lights may not be hooked up and could be grounding out.
Thanks,
Brad
Old Sep 15, 2017 | 03:09 PM
Bitburger's Avatar
Well after spending much time and many beverages looking at the wiring diagram I unplugged the stoplight switch and everything began working properly.
It seems that the harness had been repaired about five inches before the stoplight switch wrapped with eletrical tape and stuffed above the steering column. When the repair was made the wires were crossed and that apparently screwed everything up.
Thanks especially to Eric and all those who responded.
Old Sep 15, 2017 | 03:34 PM
They are always a challenge especially when dealing with previous owners repairs. Glad you stumbled on it.
Musiqone66
Apr 15, 2016 04:39 PM
64ragcut
Jun 13, 2013 09:47 AM
MN71W30
Jul 11, 2009 06:09 AM
tury801
Feb 27, 2009 01:52 AM
pompman
Oct 22, 2006 08:20 PM
