69 Cutlass headlight switch problem
I have a '69 Cutlass S 350 and I am having problems with my headlight switch heating up with the ignition switch is on the run position for a few minutes. Also, the side marker/running lights are running off of the dash light dimmer that I also part of the headlight switch. I have tried cleaning and replacing the block and chassis grounds as well and the grounds for the lights themselves. Also, I have tried buying a new headlight switch with no help. Amoy suggestions? I really don't want to end up buying a whole new wiring harness. Thanks so much for any help you can provide me!
If the rheostat is dimming your side marker lights, the headlight switch is likely defective because it's not supposed to work like that. Get a replacement and try again. Not unlikely that some of the newer cheap headlight switches could be defective out of the box.
You're probably right Eric. I just went back and read that the harness was melting the contact plug. Likely due to a short somewhere.
Thybigwheel - when did the problem start, and how long have you owned the car?
I've had it for almost a year and when I bought it that guys said that the headlight switch was heating up...I have looked at and had apart nearly every plug and socket so far. I didn't really want to rip the harness apart if I didn't have to. Do any of you know if there is a spot where a short would've been possible to make this happen?
gwunta
Jun 22, 2024 08:59 AM
rkk69olds
Jun 21, 2014 04:11 PM
brandon reynolds
Dec 18, 2013 03:05 PM
