69-98 DIRE NEED OF HELP
Old Jul 13, 2009 | 10:59 AM
wolfman98's Avatar
Captain of my ship
Well I am to the point where I hooked up the electrical the same as it was when I took it all apart. At least that is what I believe. Looking at the wireing schematics I can't see anything out of place. here is the problem. The headlights and signals work just fine but I can't get the horns to work? Also I have the added aggrevation of not having windshield wipers. When I turn them on I can hear the motor click and a little switch that looks like a U bar move but no wipers? They should work without the car running. Something else I can't do since I found that the rad is no good. the core is leaking like a sieve in 2 or 3 spots. I will have to see if I can get it recored. Any ideas on the wiper motor? is it crap or might something be hooked up wrong. Anything electrical is not my strong suit so I have no clue at this point. That's why I was carefull to put it back the same way it was.
Old Jul 13, 2009 | 07:01 PM
2blu442's Avatar
For the horns, make sure there's a good ground where they bolt to the car. The wipers, do you have the arms under the cowl screen hooked up? Is that where you see the "U" shaped bracket moving? Can you take a picture for us of the bracket that's moving? The 1973 98 parts car I'm picking up soon has a new radiator in it, not sure if it's chinesium yet, I'll have to pull it and look for a brand. If it's a good make and would fit your car it's available. I think I also have a good one from a 1978 Toronado, it's wider than the A-body and the tubes inside look great. John
Old Jul 13, 2009 | 08:08 PM
Yellowstatue's Avatar
Smile Beep beep
If you took the steering column off the steering box then make sure that the ground strap at the rag joint is intact otherwise it will remain quiet in your shop
Old Jul 14, 2009 | 03:49 AM
wolfman98's Avatar
Captain of my ship
grounds
As far as the horns the wiring for them was in a harness that went to all the lights in front. The only grounds were for the headlights and marker lights. Where would the ground for the horns be? The arms for the wipers are hooked up. When I turn the wipers on all I get is a "click". I took the cover off and looked to see what was "clicking". There is a small U shaped clip that moves up slightly when I turn them on and back down when I turn them off. The motor for the wipers does not seem to do anything? Because I have no rad currently I cannot try to fire her up , so don't know if that would change anything. battery is good and completely charged. In the service manual it says that there is a voltage adjustment screw but I cannot see anything like that. I need to get the horns working as well as the wipers to get a mechanical fitness paper done by a mechanic in order to register it otherwise it won't be on the road. I have done too much work to it to just sit in the garage.
Old Jul 14, 2009 | 04:05 AM
Oldsguy's Avatar
Past Administrator
The ground for the horn IS the horn. Each unit should be bolted solidly, the ground is through the mount, back to the battery negative terminal. A picture of the wiper mechanism would sure help out, the clicking sounds like it may be a relay.
Old Jul 14, 2009 | 04:11 AM
wolfman98's Avatar
Captain of my ship
ground
I thought it was the horns itself , I will check to make sure that they are grounded. It may have been because they were painted so I will take them off and make sure I have a metal to metal connection. I will post a picture of the wiper motor a little later. When you say "relay" do you mean internal relay?
Old Jul 14, 2009 | 04:19 AM
Oldsguy's Avatar
Past Administrator
Yes, I think there is a relay mechanism that operates the motor which is integral to that whole thing. Do you have the motor/washer pump combined set up? That thing is a nightmare.
Old Jul 14, 2009 | 04:51 AM
wolfman98's Avatar
Captain of my ship
Yes
The washer pump and wiper motor is a single unit. I will go and get a pic of it soon
Old Jul 14, 2009 | 06:20 AM
wolfman98's Avatar
Captain of my ship
pics
Going to try this for the third time. Pics are too big so I will post a link. I am pointing at the little switch. When you look down on it , it appears to look like a square U and from the side it has a piece that comes down and rests on the small plastic circular part. When i turn the wipers on this lifts off the small circular piece and makes the click sound. I tried the top plugin both ways but after looking at pics I took before I removed the pump the yellow wire should be on the right side. That is the way I tried it first. The bottom plug only goes in one way.
http://www.flickr.com/photos/wolfman98/
Old Jul 14, 2009 | 06:57 AM
Oldsguy's Avatar
Past Administrator
The thing with the reddish colored wires wrapped around it directly below your finger is a relay. The round, white plastic piece is a cam that operates the washer pump. The shaft at the center of the cam runs off the wiper motor itself. If that shaft is rotating then the wiper motor is working. As to why the arms aren't moving, you should look closer at the linkage which is what 2blu442 was suggesting. Good luck.
Old Jul 14, 2009 | 07:48 AM
rocketraider's Avatar
Oldsdruid
Wolf, if you don't have a factory Chassis Service Manual for the car, get one. It will have color wiring diagrams, working drawings showing component locations, and loads of troubleshooting charts. It also has a separate Windshield Wipers section that details what to look for and how to repair the weird things wipers will do.
But yeah, clean up all the grounding points. Bad grounds cause a great majority of the electrical issues in cars.
Old Jul 14, 2009 | 11:34 AM
wolfman98's Avatar
Captain of my ship
manual
Ok to address both of these the cam itself is not spinning so the motor is not working , the clicking noise remains and that metal square "U" that has a piece resting on the cam does move up. I do have a 69 Service Manual and will backtrack on the wiring to make sure everything is correct and grounded. Probably get at it tomorrow. Thanks guys any other ideas are of course welcomed warmly.
Old Jul 14, 2009 | 05:32 PM
2blu442's Avatar
Bruce, here's a question on the wipers. I'm wondering if the linkage is in a bind, and your hearing the electric motor click as it trys to move, but is unable to. Since you repainted the firewall I'm thinking you had to remove the wiper transmission (if that's the right word, the pieces that go between the motor and the wipers) You might look that over, I don't know if you can overtighten the fasteners that attach to the ball on the motor arm, but that might be a point that could bind. John
Old Jul 15, 2009 | 04:17 AM
wolfman98's Avatar
Captain of my ship
connection
hey John , I did take the whole unit out and repainted the firewall. I had to make a new gasket that fits between the motor and firewall. The connection to the wipers is basically a single nut that you undo to pull the connection apart so I don't think it would be binding up but it could be slightly out of alignment. I will check that this morning. Thanks for the ideas
Old Jul 15, 2009 | 06:06 PM
wolfman98's Avatar
Captain of my ship
no luck yet
Well I found that I am getting power to the wiper motor and the washer pump.I took off the motor housing but did not see any broken wires or bad connections so I put it back together then took the front plate off then plugged the motor back in and turned on the wipers. I can see where the click is coming from and there is a black plastic relay of some sort where the current from the 3 prong plugin for the motor goes through this and comes out to the wiring that goes to the motor. When it is turned on I can see a small spark inside this unit so I am not sure if it is restricted there or in the wiring to the motor. I wonder if I can take this black plastic cover apart or pull it out far enough to turn it over and see if it is accessable from the backside. good luck to me.
meoff
Site Help
Aug 29, 2013 12:15 PM
coppercutlass
Mar 1, 2013 07:33 AM
cutlassclay
May 11, 2012 06:31 AM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
