69 442 Battery Tray Help
Old Feb 6, 2026 | 03:56 PM
john.diggs442@gmail.com's Avatar
Question 69 442 Battery Tray Help
Hi all...I have a 69 442 A/T, 400 with A/C. I need to replace my battery tray & hold down; I do not have the OEM one to match up or a battery. There seems to be two sizes (7 1/4" x 10" & what they call "large" @ 7" x 12") and depending where I look I get conflicting information on what is OE. Would you happen to know how I can determine what was the OEM size or possibly provide an OEM part number or picture of your car so I can x-reference? I've looked through Fusick, OPGI and Classic Olds parts, I suspect the OEM P/N is 411303 (large). Thanks in advance...want to get it right & keep it stock.
Old Feb 6, 2026 | 04:23 PM
Sugar Bear's Avatar
I believe a 442 should have the 12" tray and an R71 battery. A 442 should also have an internal regulator with a rectangular plug into the alternator. Someone please confirm or correct this info.
Old Feb 6, 2026 | 04:54 PM
FStanley's Avatar
Large tray and correct AC Delco was a R71S the R71S will completely fill it up the tray
Old Feb 6, 2026 | 05:02 PM
rcorrigan5's Avatar
Randy C.
I have two 4-4-2 convertibles; a '68 and a'69. The reproduction "correct" battery in my '68 is R59S. I just have a replacement Delco battery in my '69. The battery trays in both cars are the 7 1/4" X 10" size which I'm pretty sure is the correct size (the length of mine actually measure closer to 10 3/8"). I got both battery trays from Fusick (part number BT6875). Fusick says the shorter tray is for cars with the 350 or 400 engines while the longer tray is used on cars with the 455 engine.
Randy C.
'68 4-4-2 convertible (Best of Class 13B at the 2011 OCA Nationals in Reno NV)
'69 4-4-2 convertible (auto, 400, A/C, as close to "numbers correct" as possible, a nice driver)
Old Feb 6, 2026 | 06:12 PM
Thanks for responding!
Old Feb 6, 2026 | 06:13 PM
Thanks for the info, John
Old Feb 6, 2026 | 06:14 PM
Great, thanks for responding & the info
Old Feb 7, 2026 | 11:01 AM
Cfos0031!'s Avatar
1969 442 came with the R69 battery originally but people replace with the R59 which is the same length just a little shorter. Should have come with the smaller tray. 7 1/4" x10".
Old Feb 8, 2026 | 02:15 PM
Thanks Craig, John
rickw30
Nov 11, 2023 07:50 AM
4-Speed
Oct 8, 2021 07:58 PM
Hurst/Olds 73/74
Sep 25, 2016 06:26 AM
442KoneKilr
Oct 13, 2015 11:15 AM
Railguy
Sep 28, 2010 06:25 AM
