68 ninety-eight no spark
Old April 10th, 2011 | 07:45 AM
scottd's Avatar
Hello and thanks in advance for any help.
Newbie here.
I have no spark and if distributor/points is issue, should I, can I convert to HEI?
any advice is most welcome.
1968 Ninety Eight convertible
ScottD
Old April 10th, 2011 | 08:00 AM
made in the usa's Avatar
Points are not that bad to play with. I put a new set in my 67 this week. Make sure you are getting power to the coil when the key is on. If so take the cap off and clean in between the points with fine sand paper or nail file. If it fires up just get some new points. I ruff set mine at 16 and put it together and hooked the dwell meter and finished adjusting them. I have the conversion kit to change mine to electronic but haven't had the time to switch it over. The points was a quick fix. Here is a link if you want to swap it over using the factory distributor
http://www.streetsideauto.com/p/pert...co-8-cyl-1181/ They don't have a bad price on the kit it runs 66 bucks.
Old April 10th, 2011 | 08:47 AM
Here is a good place to start - a thread from a couple of days ago.
carroc
December 30th, 2005 04:33 PM
colintexas
April 12th, 2004 09:20 AM
1969olds98Vert
August 10th, 2003 10:14 PM
Quick Reply: 68 ninety-eight no spark
