68 cutlass conv won't start...again!
Old August 2nd, 2016, 09:23 AM
  #41
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Where did you source the "new" starter? Is the engine a high compression 350/400/455? If so did you purchase the high compression starter or a standard duty unit? Could be the timing as Eric mentioned or the starter has a bad commutator or the copper washer is junk in the solenoid. New doesn't mean good especially with the glut of chineasium junk on our market. If it was me I would take it apart and inspect these items and return it if found faulty.You can disassemble/assemble it carefully so the counter jocky wont deny return if your versed in the starter dissection?
droldsmorland is offline
stevengerard
September 10th, 2014 03:17 PM
Octania
July 8th, 2014 04:38 PM
Jonmueller1
January 29th, 2012 06:59 PM
Salmonking
June 14th, 2011 10:20 AM
stingjim
April 4th, 2011 03:01 PM
Quick Reply: 68 cutlass conv won't start...again!
