68 442 wiring problems
Old Mar 5, 2007 | 03:34 PM
apriliarxv450's Avatar
Exclamation 68 442 wiring problems
Last ride in the 442 I had some problems. My main positive cable running to the starter grounded against my oil dipstick. It melted through the dipstick, the least of my worries. When this happened the car just shut off. When I got the cable away from the short I started the car but something wasnt right. Now the ignition never shuts off. You can turn the key off and the all the idiot lights stay on and the door buzzer sounds like the key is still in the ignition. You have to pull the battery cable so it doesnt drain the battery. I have replaced the engine wiring harness the light harness and the battery cables, starter motor, voltage regulator, points, coil, disassembled the ignition switch and nothing works. I am really frustrated with this because it is a beautiful car and I want to be able to drive it. If any of you electrical wizards know what could cause this please let me know it would be greatly appreciated. Thanks
-Justin
Old Mar 5, 2007 | 06:43 PM
ozoneblue's Avatar
Ran into somthing simular years ago wound ub being a bad body ground keeping a accessory relay closed, also pull all fuses 1 at a time starting with interior lights see if you can isolate the circut that this is on.
Old Mar 8, 2007 | 03:17 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi, I could be wrong, but I think you have an ignition relay on the firewall. It's possible the short welded it in the on position. Try this. With key off, and power to car, unpug the relays one at a time. There could be up to three, (horn, heater, ignition). If one shuts off ignition, but doesn't make a "clicking" sound when you unplug it, that should be your problem. Let us know how it goes. Jim.
Old Apr 27, 2007 | 04:53 AM
Jim's rare 80
Hey. Any luck?
Old Apr 27, 2007 | 02:48 PM
wj67442's Avatar
i had the same problem on my 67 442 i replaced the ground wire that runs from the NEG. cable to the Voltage REG. not sure if the 68 has the same set up..GOOD LUCK !!!!
chasman414
Jun 25, 2020 07:05 AM
old far
Jun 28, 2011 03:12 AM
Phil Glass
Brakes/Hydraulic Systems
Sep 7, 2010 09:30 AM
daniel
Mar 11, 2009 01:33 PM
