68 442' radio antenna in windshield.
Old Oct 9, 2020 | 11:16 AM
Brad J.'s Avatar
Putting a windshield into a 68' with the antenna built in. Does anyone have a picture of the routing of a 69' so I can see where to drill the hole for the wire. This is the short lead from the glass with 2 screw holes into it.
Thanks for any help. I would like to have it drilled and ready to go before the glass is installed.
Old Oct 9, 2020 | 12:39 PM
Yellowstatue's Avatar
'69 did not have an antenna in the glass. That started in '70 or '71.
Old Oct 9, 2020 | 12:51 PM
I did exactly this swap back in the mid-70s. You need the lead-in cable, which it sounds like you have.
That lead-in cable mounts under the rectangular hole shown here.
Old Oct 9, 2020 | 01:04 PM
Brad J.'s Avatar
Thank you Joe and Yellow.
Is that rectangle in the picture photoshopped or is it actually cut into the cowl? I can't tell from the picture and it wouldn't make any sense to me that it is cut.
Old Oct 9, 2020 | 01:09 PM
It's punched into the cowl on the 70-72 cars - that photo is of a 1970. I'll have to go check my earlier cars.
Old Oct 9, 2020 | 01:12 PM
Brad J.'s Avatar
Thank you.
I almost always search before I post and I'm coming up with some olders pictures and info that it's nothing new. Since It's not original I will try to hide it the best I can.
rkt455
Apr 2, 2020 02:57 PM
69442
Jan 23, 2014 04:10 PM
Racer24ksi
Nov 22, 2013 04:19 PM
Olds luvr
Apr 6, 2010 07:22 AM
68Tom
Apr 3, 2009 03:55 PM
