'68 442 - Ground Fault
The title pertains to not my not taking photos/notes of some items before they were disassembled.![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
I'm needing direction on where the ground wires for the front turn signal lights, side marker lights and the head lamps (from out of the wiring harness) should be attached.
Do they attach to the back of the core support at the threaded holes just to the inside of the outer head lamps (see red ovals on attached file)? Do they attach to individual locations?
Thanks for any help with this request.
Hi Tom
I think you've got the right locations but I'll look at my 1968 project tomorrow to make sure. It would be attached from the engine compartment side with a small sheetmetal style screw with a bolt head. John
1965F85_scholten
October 11th, 2013 05:49 AM
