67 Rally Pac Help
Old May 3rd, 2020, 12:54 PM
garyfoust's Avatar
67 Rally Pac Help
My dash pad in my 67 442 was shot from many years of sun. I finally got around to replacing it. When removed I took the speed and rally pac gauges in tac I only had to cut the tac wire the wire with the fuse holder to remove. The rally pac was functioning properly before removal. I put the dash back in with new dash pad and looks great only to find the rally pac is not working. I check the fuse it was good , I have power going to the tac, and the ground shield plate that runs from the back of the tac to the lighter and ignition is firmly bolted up ignition switch is bolted tight to the dash frame. I looked in the chassis manual and ran a ground wire to the back of the tac still got nothing. Whatever the issue is I have no tac, oil pressure, temp, and amp. Any suggestions appreciated. HELP! I fixed one issue the dash pad and created another issue no rally pac.
garyfoust is offline
Eightupman
November 15th, 2019 12:12 PM
damnolds
May 23rd, 2016 09:29 PM
whojohnjones
April 22nd, 2014 07:24 PM
stonecad
February 18th, 2014 10:32 AM
iam2fast4u86
June 11th, 2012 06:35 PM
Quick Reply: 67 Rally Pac Help
