67 Cutlass light switch
Old Dec 3, 2023 | 04:42 PM
cjsdad's Avatar
I replaced the wiring harness in my Cutlass and along with it, the ignition and light switch. The switches were getting sloppy and sticky. The wiring and ignition switch are performing correctly, but the light switch has let me down. Twice! The first switch was ~$13 from Amazon. I figured they're all made in China so it doesn't make a difference, right. It doesn't turn on the headlights. Confirmed with a vom, no continuity to the headlight circuit. Switch 2, I ponied up for the "Genuine GM" part. $35 , all 8 terminals, front parking lights turn off when the headlights are turned on, and everything. Still made in China, but for some unknown reason, I expected better quality. Nope! Same thing, no power to the headlight circuit. Sent that one back! Unfortunately I think I already tossed the original or it would be back in there. Anybody recently bought a light switch for a 67 that actually works?
Old Dec 3, 2023 | 06:13 PM
No power to the headlight circuit only would lead one to suspect the circuit breaker that's build into the switch.
Old Dec 4, 2023 | 02:42 AM
fleming442's Avatar
Make sure the shaft is seating correctly and the **** is not sticking out too far. Alternatively, the high beam switch is between the light switch and the lights themselves.
Old Dec 4, 2023 | 06:54 AM
I assume that when the OP says "no power to the headlight circuit", he's talking about the blue wire between the headlight switch and the dimmer switch.
Old Dec 4, 2023 | 07:44 AM
cjsdad's Avatar
Correct Joe. There is no power/connectivity between the main power input terminal and the headlight output terminal of the switch. I have replaced the dimmer switch along with all the other switches because it was also sloppy and sticky. I did not realize there was a circuit breaker inside the switch so I will check that tonight. The parking lights work though so can I assume it interupts the headlight output only? And how do I reset it?
Old Dec 4, 2023 | 07:59 AM
The breaker is self-resetting, so there unfortunately isn't anything you can do about it. It does seem suspicious that both new switches did this.
Old Dec 4, 2023 | 08:22 AM
fleming442's Avatar
If the breaker is resetting on 2 separate, new switches, that would indicate a load that is too high or a dead short.
Unplug the headlights, and see if it works (power out). If so, it's the, or a, bulb(s). If still no power, there's a short.
Old Dec 4, 2023 | 08:25 AM
Correct, but if the connector at the dimmer is unplugged and there is still no power on the blue wire, then either there is a hard short to ground somewhere in that blue wire or the breaker in the switch is bad. Verify that there isn't a problem at the connector to the switch. Unplug both the dimmer and the headlight switch and see if there is continuity from the blue wire to ground.
Old Dec 4, 2023 | 09:15 AM
cjsdad's Avatar
Thanks Guys! They are new LED headlights and they worked before, so I will see if there are any problems with the wiring. There shouldn't because I kept the factory wiring for the lights under the hood. It was still in very good condition. Sideways points of view always help with diagnostics. I'll let you know what I find.
Old Dec 4, 2023 | 10:33 AM
fleming442's Avatar
You really need to bench test those lights first. Figure out which is power and ground, then use a battery to make sure they're wired correctly. The H4 and sealed beam plugs are the same, but pinned differently, I believe. They could be on the H4 pinout, wired backwards polarity, or just defective, because....... China.
Old Dec 4, 2023 | 10:35 AM
Again, if there isn't power on the blue wire from the switch to the dimmer, the headlights are irrelevant. Don't make work.
Old Dec 4, 2023 | 10:38 AM
fleming442's Avatar
Understood, but you of all people should be the first to discount the quality of a non-OEM part. I've had LEDs wired backwards right out of the box, and LEDs don't work backwards.
Old Dec 4, 2023 | 10:47 AM
From Post #9:
So the lights were working with the old headlight switch, and the only thing that has changed is the switch.
Old Dec 4, 2023 | 10:49 AM
If you want more fun than checking for grounded hot wires, get a cheapie inline fuse holder, load it up with whatever the equivalent fuse is, and jump around the headlight switch. Set up with battery disconnected. Connect battery; you'll either blow fuse (short), lights will work, or they won't.
Please bench test the switches with ohm meter (on your work bench, not in the car), also check the case of the switch. I bet the case is grounded when you turn the headlights on and the breaker goes.
Old Dec 4, 2023 | 01:18 PM
cjsdad's Avatar
LOL! Lots of fun stuff related to a simple light switch. Since the switch has no conductivity to the headlight circuit after it is unplugged, I'm guessing the internal circuit breaker is now bad and won't reset. I will probably end up with a fuse holder wired in-line if possible. That being said, the lights did work with the original light switch and dimmer switch, highs n lows. All I did to the wiring for the front lights was re-wrap them with cloth wiring tape, but something has gone wrong. Knowing that there is a breaker in the switch gives me a starting point that I didn't have before. Like I said, I'll let you know what I find.
Did that... Said so in my first post.
Can you give me a little bit more on that? How will the case become grounded with the switch turned on? Through the headlight wire if it is touching ground? Once it is installed, the case of the switch would become grounded through the grounding straps on the back of the dash anyway, right? If the case can become grounded through the headlight wire, wouldn't that mean it can become energized by that same headlight wire? And would therefore blow a fuse or trip the breaker as soon as the switch was turned on? You got some 'splaining to do Lucy!
Old Dec 4, 2023 | 01:59 PM
The case of the switch is grounded upon installation and the only purpose of that ground is to complete the courtesy light circuit. What happens if you jumper the plug with a paper clip?
Old Dec 4, 2023 | 02:02 PM
Just in case, I would make that a FUSED "paper clip"...
Old Dec 4, 2023 | 02:18 PM
With the installation of the new headlights are there new relays to go with it that are controlled by the dimmer switch?
Old Dec 4, 2023 | 05:45 PM
cjsdad's Avatar
Figured it out, my worthless assistant plugged the main power lead back into the wrong spot after I cleaned the connector! The lights work correctly now.
And just to satisfy curiosities, the headlights are plug-n-play.
Old Dec 4, 2023 | 05:50 PM
Congrats. For some reason people want to immediately go to esoteric reasons for a problem. Always check the simple first.
Old Dec 4, 2023 | 05:57 PM
fleming442's Avatar
Yeah, because we all knew the connector was repinned
Old Dec 4, 2023 | 06:43 PM
No, because we all knew that the problem had to be between the headlight switch and the dimmer.
Old Dec 4, 2023 | 09:08 PM
I'm glad you have it figured out. What I meant was that the hot side could be shorted to ground at the terminal out to the headlights. It would only be tripping when the switch is to headlights as the short is behind the switch in this example.
However, since you've got it, we can instead talk about I Love Lucy. The phrase "you've got some 'splaining to do, Lucy!" was used on occasion by Desi Arnaz towards Lucy when she had made a mess of things and he was demanding to know why. It shouldn't be used when someone is trying to help you and you don't understand the information.
Old Dec 5, 2023 | 04:16 AM
cjsdad's Avatar
Even if the headlight circuit were shorted to ground, the switch casing would not have been "hot". That circuit doesn't make contact with the case. Now if the dash light circuit became shorted, it would.
Thanks Yoda!
Old Dec 5, 2023 | 07:29 AM
Thanks Yoda!
Hrrrm, yes, much wisdom you now have.
Old Dec 5, 2023 | 08:24 AM
cjsdad's Avatar
Now we're cooking with gas...
Old Dec 6, 2023 | 08:45 AM
Oldsmaniac's Avatar
Reminds me of an old thread on a quadrajet flooding no matter what he tried. Come to find out he had an electric fuel pump, not mentioned, no regulator not mentioned and 20 psi...hmmm more info is always good.....
Rocket Olds
Dec 23, 2019 03:34 AM
dave marki
Sep 1, 2015 10:43 AM
66olds98convertible
Sep 27, 2014 06:48 PM
FirstClass 383
Aug 6, 2013 06:17 PM
cbogartjr
Apr 8, 2010 07:09 AM
