67 cutlass Alternator vs Regulator
Old May 11, 2017 | 12:51 AM
brianbeez67's Avatar
I am rebuilding my 67 C/S 330, 4 barrel, After searching my garage the only thing I have found was the original voltage regulator- (Lost / thrown away years ago is the Alternator). Can't determine the capacity if you will of the regulator so then I can get every ones advice on amps for the alternator. As always any and all advice is good
later Brian
Old May 11, 2017 | 03:59 AM
The VR operates on voltage and is compatible with most alternators. If your going with a new alternator I recommend getting a Wells PN-VR715 solid state regulator, its plug and play.
Old May 11, 2017 | 04:55 AM
Eric's suggestion is a good one.
I will add that the original alternator was probably 32A. If you have any additional modern equipment at all, you will likely need a higher output unit anyway.
Old May 11, 2017 | 08:04 AM
Oops! I didn't read that Eric mentioned a solid state voltage regulator.
Anyways, I think you should make the jump and go solid state all the way and get a one-wire alternator. Here's the one I have on my 71 98. It works great and the price is actually comparable to what it would cost at an auto parts store:
http://www.jegs.com/i/JEGS-Performan...10120/10002/-1
Old May 13, 2017 | 08:26 PM
Junkman's Avatar
From memory, in 1967, they were 37 amps for all cars, except the air conditioned cars, which got a 42 amp alternator. Usually, you can find the original part number in the FSM in the electrical specifications page. Once you have the correct part number, enter that into the eBay search engine, and see what comes up. Don't forget to check completed auctions, for one that didn't sell, nor were they relisted.
Old May 13, 2017 | 08:40 PM
66-3X2 442's Avatar
A/C cars had 55 amp alternators.
Old May 13, 2017 | 10:47 PM
then a 55 amp alt (I have A/C), what should the Voltage regulator be rated for?
I would like to keep everything stock in the beginning since I will be putting all new wiring harnesses in, (looking/hoping) for the least problems on the initial start up
thanks Brian
Old May 14, 2017 | 06:14 AM
Again, get a solid state VR. The one I suggested above (VR715) is a proven plug and play unit using your original connector that will eliminate the headlight dimming issues and erratic charging of the old mechanical ones. You can also swap the cover off your original one to give your the stock look.
yeahbuddy
Dec 1, 2011 10:29 PM
D Appeldorn
Apr 1, 2011 11:25 PM
71 Cutlass
Sep 23, 2010 07:32 PM
68conv455
Jan 12, 2010 09:19 AM
musicars
Jun 9, 2008 11:02 PM
