67 cutlass 4 spd backup light switch
Old Jan 13, 2020 | 03:55 PM
Rocket Olds's Avatar
Looking at 4 pages of back posts on issues of back up light switch and cant find a pic of 67 4 spd whereby the back up switch is mounted on the passenger side of trans only see earlier 4 spd and they are mounted on driver side. I have new correct switch but cant seem to understand exactly how to mount it. It seems the connecting rod will hit the bracket and not let the switch turn on. When using ohm meter the arm has to travel further down and when this happens either the rod or the arm will hit the bracket and not go into position to allow lights to come on. so maybe a pic of the actuator rod will show that I either have the correct one or not? As always thanks, Mike
rod hits
arm hits
is this correct rod?
Old Jan 16, 2020 | 04:20 PM
I figured it out myself. Mainly I was confused as laying under the car (old school) looking upside down and realized that I mentioned switch was on wrong side but was not afterall. My bad. I figured it out that the switch was correct and on correct side of trans and the lever actually goes opposite of what I thought when I had it out of the car. I installed new switch so everything works now as it should. thanks to everyone that read this post and had a good laugh and did not make a fool out of me publicly but instead allowed me to discover for myself the fact that I did know what I was talking about nor what I thought I saw while laying on my back. I must have been drinking my bathwater again. Thanks, Mike
Old Jan 17, 2020 | 05:35 AM
classicmuscle442's Avatar
Well done figuring it out, maybe post a picture of it installed to wrap up the thread for future searches.
Old Jan 17, 2020 | 09:03 AM
lemoldsnut's Avatar
I usually figure stuff like that out at about 3 am and have to get up and go do it right then.
Old Jan 17, 2020 | 05:28 PM
Yellowstatue's Avatar
3 am
Exactly...
Old Feb 3, 2020 | 06:23 AM
here is pic of final install. I had not purchased the whole kit for a switch which includes a bracket that I had already and a splash shield that I did not know about until I had sent off for the switch cause mine was missing. at this point I am not going to purchase one as I dont plan getting caught in the rain. But that is me. Also notice the arrow pointing to the "external hair pin clip" after many trips to several places I did find these at Home Depot in a pkg of 2 for $.76 . I probably spent $10.00 in gas so you wont have to. By the way I installed my switch with 4 speed in reverse and I had to bend the connecting rod a little and pivot the switch a little to make sure that switch was engaged and had continuity at the plug end before wrapping up. Hope this might help another beginner like me.
note hair pin clip
Old Feb 3, 2020 | 11:01 AM
rob1960's Avatar
I believe your switch is upside down, pic is from my '68 right after I rebuilt the trans, same setup as '67. The small link rod wasn't connected to the reverse lever in this pic as I was adjusting the linkage.
Old Feb 3, 2020 | 12:24 PM
You maybe right but the way I hooked mine up was the way is was when I removed it. Doesnt mean I was right it just was the way it was. I will do some checking for other pictures to see . But I do like the way wire harness is ran. Obviously it can be mounted either way.
Old Feb 3, 2020 | 02:54 PM
Very nice install and thanks for picture, now I need to find a setup for my '65
Old Feb 29, 2020 | 04:10 PM
finally got around to checking to see if it worked properly, and it did NOT.. Rob1960 You were right about being upside down. When I finally checked it the lights worked but they worked all the time the key was on. 2 problems; first installing upside down made the connecting rod from switch to reverse lever hit the bracket, second was me thinking that if trans was in reverse when installing that everything would fall in place....WRONG, got to use the alignment holes and trans in neutral. Works like it is supposed to now. Thanks to all, Mike
Old Mar 1, 2020 | 04:04 AM
rob1960's Avatar
Glad it worked out for you!
Rocket Olds
Dec 23, 2019 03:34 AM
sortasane
Nov 27, 2015 08:05 AM
Sid
Nov 22, 2014 05:16 AM
66olds98convertible
Sep 27, 2014 06:48 PM
FirstClass 383
Aug 6, 2013 06:17 PM
