67 442 wiper motor issue
Guys I discovered when I drove the car home in the rain from a Olds Regional meet my 2-speed wipers would only work if I kept my finger pushed in like your going to use the washers. Both speeds would work as long as I kept my finger pushed in keeping the washer mode on? Obviously the motor works, I'm assuming it's the switch? I want to make sure before I figure out how to remove the dash-I don't how else you can change it out on a 67 A-body
Pull the **** off then turn or loosen the escutcheon, collar that holds the switch on the dash. Reach behind and pull the switch out. If you have to remove it. I had to move the wiring harness around to get mine to work, loose wire somewhere. Haven't found it yet.
My 1967 4 door went through a bout of that last winter. I removed the switch, cleaned up the surface where it contacts the ground strap back of the dash. I also lightly sanded the mating surface of the ground strap with emory cloth, re-installed and its worked fine every since! John
I removed the wires on the wiper motor and washer, sprayed the contacts with Radio Shack contact/control Cleaner@lubircant. Then reached up (barely) under the dash wiggled the contacts/wires back and forth, re-set them WHHLAA I got wipers!
Thanks guys.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
oldspackrat
March 12th, 2015 06:34 PM
Dead Reckon
July 14th, 2014 02:35 PM
