67 442 LH inner fender ground wire Help
Old Jul 21, 2013 | 06:22 PM
garyfoust's Avatar
I have a 67 olds 442 and on the driver's side inner fender towards the front inside above the steering box I have a factory ground that is attached and factory. The wire is brown but have no idea what it goes to. Please help!
Old Jul 21, 2013 | 06:59 PM
Octania's Avatar
Did you ck the assembly and chassis service manuals?
Can you post a pic?
Sounds like the ground from battery cable to radiator support for front lighting. Next to the battery.
Old Jul 21, 2013 | 07:03 PM
jeffsims's Avatar
1967 442
In the middle my my '67 442 resto. The only brown wire I have in this area has a black rubber cap to protect its connector. It snaps on top of the brake manifold valve that is mounted to the frame directly below the booster/master cylinder.
Old Jul 21, 2013 | 07:16 PM
65B01Delta's Avatar
x2, The wire goes to your bake proportioning valve mounted on the frame.
Gary, The wire goes to this part. It's mounted on the driver side frame right behind or close to the wheel. See picture....
Old Jul 21, 2013 | 07:25 PM
garyfoust's Avatar
Thanks Bill. R U stepping up to locate a 69 H/O or just curious about that thread?
Old Jul 21, 2013 | 07:26 PM
65B01Delta's Avatar
Just Curious....
Old Jul 23, 2013 | 09:41 PM
BILL DEMMER's Avatar
Just the facts...
ernie has the same thing, it was connected to the - battery cable. not saying that it's stock, but it's what he had. he's getting improved upon. lol
bill
Sea five
Jan 9, 2015 09:33 AM
JPMDaddy
Oct 20, 2013 08:21 AM
Tedd Thompson
Jul 25, 2012 02:06 PM
davebw31
Mar 25, 2011 06:55 AM
Redog
Mar 11, 2008 10:37 AM
