67 442 Instrument Cluster not working
Old Aug 7, 2015 | 12:11 PM
Pewter442's Avatar
So I got the new dash from Ron in and the new dash wiring harness in and all new fuses and everything works but all the dash lights including the dummy lights, turn signal indicators and back lighting. Any Ideas?
Old Aug 7, 2015 | 01:30 PM
Not sure about the turn indicators - that may be you just don't have both of the flashers in? Check the rheostat for dimming the dash lights. Do you have it cranked all the way off?? Either that or you have a bad electrical connection somewhere. Check them to make sure they're tight.
Old Aug 7, 2015 | 01:43 PM
I would check your grounds.
The idiot lights generally work by grounding through their respective sender switches, but all of the others have to have a ground to work.
Make sure that all of that nice, new, perfect paint on all of those surfaces isn't insulating the dash from the car - I'd probably just run a ground from a central dash point to a solid metal bit and see what happens.
Old Aug 7, 2015 | 03:36 PM
lemoldsnut's Avatar
I put an extra ground on mine from the screw that makes the ground from the lighter area to the back of the printed circuit to the steering column mount. Made a great difference. Also on all the dash mounts to the metal of the dash I used those little star type grounding washers. Can't be too careful with wiring.
Old Aug 7, 2015 | 04:09 PM
therobski's Avatar
X3 guys on the grounds, if I recall correctly the copper ground from the back of the pass side head to the firewall is the ground for sat least the dash? My example is from my 64 F-85 Pro-Touring build and is attached to the valve cover.
Old Aug 7, 2015 | 05:55 PM
Bad ground, bad ground, that's grounds for creating electrical gremlins. Yes, these old cars are notoriously dependant on grounds. Hope the problem gets solved without grounds for going nuts.
Old Aug 7, 2015 | 06:19 PM
Pewter442's Avatar
Thanks guys. Yeah I'm going to try and add a ground strap from the dash to the firewall and see what happenes. It's just frustrating cause everything is new.
Old Aug 7, 2015 | 07:02 PM
2Olds4U's Avatar
Majored in rear tire demo
At the risk of sounding stupid, what DOES work? The fuel gauge and high beam indicator? Rally or standard dash?
If a standard dash, maybe a bad pin or solder landing on the PC?
Old Aug 7, 2015 | 07:15 PM
Pewter442's Avatar
Now that I think about it. The only thing that does is the fuel gauge. It's a standard dash. And the headlight switch is brand new and turned up.
Old Aug 7, 2015 | 08:51 PM
steverw's Avatar
there should be a ground wire in the harness i believe, somewhere above the steering column/ brake pedal bracket. It grounds to that bracket with a 1/4 inch hex head screw. However extra grounds cant hurt anything. Battery to engine, engine to frame and firewall.
Old Aug 8, 2015 | 12:38 PM
Pewter442's Avatar
Yea all that is their. I'm just at a lose.
Old Aug 8, 2015 | 12:42 PM
RandyS's Avatar
How about the lights in the radio & ash tray? If they work and the bulbs in the cluster don't, it is something with the wiring to or on the circuit board. If none of them work, I would look at your new harness.........
68RocketAction
Jun 7, 2013 09:21 PM
carnell71075
May 1, 2010 07:37 PM
gglow
Jan 19, 2010 03:31 PM
carnell71075
Jan 9, 2010 02:34 PM
Oldsmobilliam
Dec 1, 2009 05:56 AM
