66 Olds Cutlass running lights
Hi everyone, new to this forum and I have a question hopefully someone has an answer for? I have a 66 Cutlass that was my dad's and now I'm working to get it drivable again. My question is this, when I turn on the headlights, I only have running lights in the rear, not the front? However, if I just turn on the running lights, both front and rear work fine. Both work on the turn signals and flashers just not when the headlights are on? I replaced the switch thinking that might be the problem but it still persists. Am I missing something? Thank you in advance for any ideas you have.
Yes, you are missing something. Parking lights were not on with headlights until 68. In 67 and earlier, what you describe is correct behavior. Saves bulb life and lens heat issues, too. You are good to go.
