66 442 kickdown switch
Old Nov 13, 2012 | 07:32 AM
bobfo1's Avatar
Can I use the stock kickdown switch on a 66 442 that originally had a Jetaway if I am now using a T400 or do I need to use a later model kickdown (like a 67)?
Old Nov 13, 2012 | 07:40 AM
dancutlass's Avatar
You can use the one you have! Just connect the yellow wire to the terminal at the transmission and leave the yellow/black one disconnected...
You can measure it, too, as you have to have 12V at the transmission at WOT!
Old Nov 13, 2012 | 07:58 AM
X2 - using what ya got.
Old Nov 13, 2012 | 09:41 PM
White_Knuckles's Avatar
I found a kickdown switch from B&M you can bolt to your carb mount or manifold. It's adjustable so you can Jetaway from a trigger point before wide open. I set mine to launch as soon as the secondarys crack open. Wheeee!!
|-K|=K
Jan 11, 2011 06:45 PM
Flye
Jul 15, 2009 09:25 PM
Flye
Apr 2, 2009 05:17 AM
Satellitecentral
Mar 18, 2009 05:38 PM
nevadacutlass
Oct 8, 2007 07:28 PM
