65 Delta Headlights wont turn off
Old Mar 21, 2016 | 09:47 PM
AtomicMyke's Avatar
Hey All,
My 65 Delta 88 threw a strange on atme today that when I git home from work, i went to turn off the headlights and they stayed on, even after the switch was in the off postion and fully in. the tail lights and dash lights all turn off. how ever the headlights remain on!, i even unplugged the harness to the headlight switch but still they stay on. I can even switch between high and low beams with the foot switch even while the lights are off. and ideas as to where this might be coming from?? thanks!
Old Mar 22, 2016 | 03:43 AM
That's a good one.
The only possibility I can see is part of the headlight switch inside physically broken off,
unless the car has a burglar alarm, or some similar aftermarket gizmo installed.
Old Mar 22, 2016 | 05:30 AM
m371961's Avatar
If they stay on with the switch unplugged I wouldn't think it is a switch problem. Is wiring all original? Does it have any relays or, as Eric says, aftermarket gizmos?
Old Mar 22, 2016 | 05:39 AM
Is there any chance this car has the Twilight Sentinel or Guidematic system?
Old Mar 22, 2016 | 06:14 AM
D'oh. Too early in the morning. Missed that.
Old Mar 22, 2016 | 08:03 AM
Octania's Avatar
Yeah that is some good voodoo right there.
automatic leaver-onner is my best guess.
If you take the wire right off the bulb and it stays on, you have a money making trick there.
Old Mar 22, 2016 | 08:28 AM
Yeah, the Guidematic Eye shouldn't be the problem, because it should get both its operating power and its relay supply from the headlight switch Headlight terminal, so an aftermarket thing is pretty much all that is left, unless someone rewired the Twilight Sentinel.
Of course, if, as Chris says, you pull the wire off the bulb and it still stays on, you've got something there...
Last edited by MDchanic; Mar 23, 2016 at 02:47 PM. Reason: Whoops - not the Twilight Sentinel.
Old Mar 22, 2016 | 12:49 PM
Octania's Avatar
I had a torch once, propane, the kind that screws onto the tank. I guess its filtery thing was plugged or something, 'cause I turn the **** off and the flame continued.
Unscrewed the torch from the tank it STILL burned...
for a minute or so
Old Mar 22, 2016 | 12:54 PM
for a minute or so
They all do that. The propane in the neck of the torch doesn't instantaneously dissipate. Unlike electrons, gas doesn't move at the speed of light.
Old Mar 23, 2016 | 04:28 AM
AtomicMyke's Avatar
Unfortunately it seems i havnt discovered a source of unlimited power as i unplugged the bulb directly and it went out. There goes my get rich quick idea. Somehow I managed to "solve" the problem. I use the that quotes liberally and I still have no clue what happened. I fiddle with the dimmer switch wires a little and the symptoms stopped, s ok I have no clue, hasn't come back since....
Old Mar 23, 2016 | 09:45 AM
The dimmer switch only gets power from the headlight switch, on the blue wire. If the problem persisted when the headlight switch was physically unplugged, then the ONLY possible cause is that this blue wire is shorted to power somewhere between the headlight switch and the dimmer switch. I would suggest inspecting it carefully, as shorts to power can lead to fires, especially in this case where the short would have to be AFTER The circuit breaker in the headlight switch. I would especially look at the connector to the headlight switch, where the red power input wire and the blue wire to the dimmer switch are pretty much next to each other. Often the connector can overheat and melt the plastic body. I had this happen on a Chevy truck.
Old Mar 23, 2016 | 02:44 PM
rocketraider's Avatar
Oldsdruid
No Twilight Sentinel on Olds in 65. That came around 1970 or so.
I suppose a Guidematic could cause something weird like this if the GM specific dimmer switch had been replaced with non-GM dimmer.
Old Mar 23, 2016 | 02:47 PM
Whoops. Guidematic Eye.
Big Mikey
Jun 9, 2013 07:50 AM
jpc647
May 18, 2013 02:08 PM
Gary's 2 442-S
Feb 16, 2011 07:34 PM
cutlass47
Nov 6, 2010 07:39 PM
