65 Delta Headlights wont turn off
Hey All,
My 65 Delta 88 threw a strange on atme today that when I git home from work, i went to turn off the headlights and they stayed on, even after the switch was in the off postion and fully in. the tail lights and dash lights all turn off. how ever the headlights remain on!, i even unplugged the harness to the headlight switch but still they stay on. I can even switch between high and low beams with the foot switch even while the lights are off. and ideas as to where this might be coming from?? thanks!
That's a good one.
The only possibility I can see is part of the headlight switch inside physically broken off,
unless the car has a burglar alarm, or some similar aftermarket gizmo installed.
Yeah, the Guidematic Eye shouldn't be the problem, because it should get both its operating power and its relay supply from the headlight switch Headlight terminal, so an aftermarket thing is pretty much all that is left, unless someone rewired the Twilight Sentinel.
Of course, if, as Chris says, you pull the wire off the bulb and it still stays on, you've got something there...
Last edited by MDchanic; Mar 23, 2016 at 02:47 PM. Reason: Whoops - not the Twilight Sentinel.
I had a torch once, propane, the kind that screws onto the tank. I guess its filtery thing was plugged or something, 'cause I turn the **** off and the flame continued.
Unscrewed the torch from the tank it STILL burned...
for a minute or so
for a minute or so
They all do that. The propane in the neck of the torch doesn't instantaneously dissipate. Unlike electrons, gas doesn't move at the speed of light.
Unfortunately it seems i havnt discovered a source of unlimited power as i unplugged the bulb directly and it went out. There goes my get rich quick idea. Somehow I managed to "solve" the problem. I use the that quotes liberally and I still have no clue what happened. I fiddle with the dimmer switch wires a little and the symptoms stopped, s ok I have no clue, hasn't come back since....
No Twilight Sentinel on Olds in 65. That came around 1970 or so.
I suppose a Guidematic could cause something weird like this if the GM specific dimmer switch had been replaced with non-GM dimmer.
oldspackrat
Jan 20, 2015 09:16 AM
Big Mikey
Jun 9, 2013 07:50 AM
