65 Cutlass Horn Problem
Old Jul 20, 2007 | 06:14 AM
jordanph's Avatar
Ok, when i press the horn button, the relay clicks. I've been told this means the relay is fine, but when i jump accross it, the horns blow. Its one of those horn relay/battery cable junction blocks. Any ideas?
Old Jul 20, 2007 | 08:37 AM
Oldsguy's Avatar
Past Administrator
The relay clicking doesn't mean that is necessarily good. I would bet on the relay. If you have a voltmeter or one of those indicator troubleshooting light bulb pens then check for a switched voltage when the relay clicks. If it isn't there you have a bad relay.
Old Jul 20, 2007 | 10:34 AM
jordanph's Avatar
Thanks. I've had the multimeter to it and there's no switched voltage. Hopefully i win my bidding war for the realy on ebay.
Old Oct 29, 2007 | 06:54 PM
markowyo's Avatar
relay contacts can be easily cleaned and made to work like new with some emery cloth
Old Oct 30, 2007 | 04:56 AM
Oldsguy's Avatar
Past Administrator
Very true mark, if you can disassemble the box and reassemble it. I just change the relay if one is available as I find that to be easier.
Jordan, what did you do to solve your problem?
jlauffer
Jun 30, 2015 05:53 PM
joepenoso
Jul 12, 2013 11:03 AM
DennisG.
Apr 15, 2012 11:01 AM
redvettemike
Aug 15, 2009 07:04 PM
elcaminodave
Sep 30, 2008 06:16 PM
