65 Cutlass convertible top stopped working
Old Aug 15, 2009 | 03:17 PM
dingusboy's Avatar
The top on my 65 vert just stopped working. I put it up and when I went to put it down....nothing. No motor noise or anything. I checked the circuit from the plut to the switch and I have power to the switch. I checked the circuit on the pump. Looks good. Any ideas? The fuses look good. I'm not sure which is for the top though. I still think it is an electrical issue.
Old Aug 15, 2009 | 06:05 PM
Lady72nRob71's Avatar
plut? Not sure what that was meant to be but if there is power at the switch, that is a good start.
Are the wires that go to the switch thick or thin?
If thick (10ga) then no relay was used and the switch could be bad.
If the wires are thin then perhaps a relay was used and power to it should be checked. (could be powered through a different circuit than the switch)
Luckily it stopped in the up position...
Old Aug 25, 2009 | 05:48 AM
dingusboy's Avatar
Thanks Rob. Got it fixed. I had front discs put on. Looks like an electrical connection behind the MC got loose. It's good to go.
atkinsom
Oct 16, 2014 07:07 PM
Maverick
May 7, 2013 04:20 PM
Southern_Hospitality
Oct 3, 2011 07:50 PM
brown7373
Feb 26, 2011 08:44 PM
agtw31
Apr 26, 2010 10:20 AM
