6 cyl to 8 cyl tic-toc-tach
Old November 29th, 2009 | 05:52 PM
68conv455's Avatar
Does a tic-toc-tach have provision to switch from a 6 cylinder to an 8 cylinder engine. I bought my 68 cutlass with a 6 cyl, now it has an 8 cyl. Do I need to do something with the tach to make it read correctly?
Old December 8th, 2009 | 05:19 PM
68conv455's Avatar
Don't tell me I've stumped you.
My tach reads 1800 RPM and my Engine Analizer reads 1200 RPM.
I know this doesn't match up perfect, but I'm guessing that the Tic-Toc-Tach should read 1600 if I ratio it out to the number of cylinders.
Anyone know about this? Can I get this modified somewhere?
Old December 8th, 2009 | 06:28 PM
stevengerard's Avatar
I don't know about 6 cyl to 8 cyl but if you search the threads here there is information on how to calibrate the tach which may help
Old December 8th, 2009 | 11:30 PM
svnt442's Avatar
That is only a little. I don't think that will convert it from 6 to 8 cyl.
It would require a different resistor I'm sure, but I wouldn't know which one or what value to replace it with.
Old December 12th, 2009 | 07:39 AM
68conv455's Avatar
Can anyone recommend a gauge shop to send it to?
Old January 11th, 2010 | 06:46 PM
68conv455's Avatar
Ttt
Old January 11th, 2010 | 11:16 PM
Bob's speedometer repair in Howell Mi. He's listed in Hemmings.
Old January 11th, 2010 | 11:18 PM
http://www.bobsspeedometer.com/1/120/index.asp
Old January 11th, 2010 | 11:37 PM
Eightupman's Avatar
http://www.bobsgauges.com/servlet/th...Cutlass/Detail
Its only $1200. I'd buy a repop first. Same concept as what Bob does.
Old January 12th, 2010 | 04:39 AM
Bluevista's Avatar
Registered
Rob would know how, he could build one from scratch out of a brick and a paper clip.
Where are you Rob?
70cutlasssupreme
January 24th, 2022 03:30 PM
gdam
March 10th, 2008 06:40 PM
TheRuss
May 23rd, 2007 04:57 PM
