20a dir sig-back up fuse blew
#43
Eric - That is exactly what I did - untwisted it plus wrapped the leads in e tape.
Norm - Years ago I did have to go thru the 6C-13 when I thought then found out my DVCV was not working. At the time it did not increase the idle when the temp rose to a certain level (can't remember what temp any longer) . So I went thru the test and replaced it, and it's been working ever since - that is until some bonehead squished the resistor together and caused a short. But you are correct - glad I didn't have to do it tonight.
Thanks Guys - I appreciate all the help.
#44
dougherp - Glad you found it, good work! Sorry for the incorrect troubleshooting info!
old cutlass - Thank you for pointing out that a bulb, solenoid coil etc. would show continuity to ground...didn't think of it. Sincerely appreciate the education!
Good luck!!!
Good luck!!!
