1985 regency no injector pulse
Old May 18, 2025 | 01:13 PM
Jacksonmusolf's Avatar
Just got this car for free and it sat for a long time in a barn where squirrels got into the engine bay and chewed wires I have repaired all wires to my knowledge without a schematic. Everything seems to now work correctly except the injectors. They have power to them with key on but do not pulse wen cranking over. I cannot find any wore schematic or info online. I know the 85 year is not as popular I would pay someone for help! Or pay someone for schematic! Thank u
Old May 18, 2025 | 06:02 PM
Turnpike's Avatar
https://www.alldata.com/diy-us/en/find-vehicle
contact them - see what data they have available
they are currently running a discount - use promo code SPRING for 15% off
Old May 18, 2025 | 06:06 PM
gs72's Avatar
72Cutlass S
Do you have spark?
Old May 18, 2025 | 07:11 PM
I had Bishko manuals for my 96 98 before I got an OE printed copy.
https://www.bishauto.com/
You could always use a test light to check the fuel injectors for 12 V while cranking.
Old May 18, 2025 | 09:01 PM
gs72's Avatar
72Cutlass S
Spark and injector pulse width are related. They both get the trigger signal from the distributor, Usually in those years the ignition and the injection system work independently of each other, the ECM only controls the spark timing, so you can have spark and no injector pulse at the same time. Does the check engine light come on when you turn the key on? If not this indicates that ECM is not powering up. Check the reference voltage to the sensors, unplug the Throttle position sensor and check voltage at the reference voltage terminal it should be 5 to 9 volts depending on the year. Another thing thar can cause no injector signal is a out of range MAP. Sensor. Unplug the MAP sensor connector and see if it tries to fire. It will run like **** but it should try to start. I have seen out of range MAP sensors read in the 9000 ft elevation range which would lean it out so bad the it will not start at anything close to sea level.
Old May 19, 2025 | 12:00 PM
There is no engine light when key is turned on I have 6v to throttle position sensor. Not sure witch wores over by the battery power up the computer.
NEVERMIND I DO NOT HAVE 6V AT TPS NOW AND I SWEAR I HAD ENGINE LIGHT ON BEFORE.
Old May 19, 2025 | 12:40 PM
gs72's Avatar
72Cutlass S
If your ECM is not powering up it cant turn on the fuel pump
Old May 19, 2025 | 01:02 PM
66_Jetstar's Avatar
If you have no pulse or CEL then its likely the computer is dead.Those distributors will spark with no computer input, so it may fire off with ether or gas down the intake. The easiest thing to check first are the fuses for the computer. There should be two in the box below the dash.
Old May 19, 2025 | 03:42 PM
Ok I now have injector pulse and fuel pump. It tries to start but will not. I believe it is the map sensor on top of the engine with a 4 pin plug not 3 pin. The sensor has a vacuum line that goes too it and 2 wires go from it hard wired into a syloniod with another vacuum line coming off that it is located by the fuel pressure regulater. I cannot get this part at the store and everything I find online has a 3 wire plug and no syloniod. I believe 1985 was a one year setup and cannot find info. Thank u for all the help everyone I wanna get this baby going tonight lol
Old May 19, 2025 | 03:56 PM
Also I used fuel pump from tbi 350 they were the exact same pump
Old May 19, 2025 | 04:23 PM
66_Jetstar's Avatar
That's a problem. TBIs run at 13-15 psi. I believe the regency has MPFI that needs 45 psi. That pump won't work.
Old May 20, 2025 | 03:42 AM
Could you post a pic of the sensor?
Old May 21, 2025 | 06:29 AM
switched back to original fuel pump seems to run better. I believe i need these parts for it to run right but not sure
Old May 21, 2025 | 06:37 AM
Dynoking's Avatar
I do not think that is a MAP sensor. It looks like a EVAP purge valve. I do not think your car even has a MAP sensor. I believe it a Mass Air system, and uses a Mass Air Flow sensor.
Old May 21, 2025 | 02:44 PM
So do u think I need these sensors? I got everything done and fixed runs funny still and has engine light on. Also had a power steering line blow out and fixed it but can't get the system to bleed out. You have all helped alot on this I have never used a forum before it is quite awesome
Old May 21, 2025 | 03:47 PM
All of the emissions equipment needs to be present or your car won't run right.
Old May 21, 2025 | 04:54 PM
Does anyone know how the system works there's tons of vacuum lines and crap that are ate up. This must b a one year car or something I can't find any information
Old May 22, 2025 | 04:33 AM
You mentioned earlier that you didn't see a Check Engine Light with the key on. We're you ever able to pull codes?
Old May 22, 2025 | 06:39 AM
The check engine light was off because the computer wasn't on. I have it now and have not checked it yet I have been fixing other problems I'm getting close just not sire how all the vacuum lines ran before
Old May 22, 2025 | 07:56 AM
Hammerdrop's Avatar
You should reread post #2. Alldata could be very helpful with wiring diagrams and other service data. Spend a little $$.
Old May 23, 2025 | 05:20 AM
Dynoking's Avatar
Xwhutestripex
Non-Olds Engines
Aug 5, 2024 05:35 AM
Danoby
May 27, 2023 06:16 AM
nicks1966
Nov 13, 2022 04:29 AM
pjmia96
Jun 1, 2016 07:05 AM
Automobubbling
Sep 4, 2013 06:39 PM
