1984 hurst olds tach reads wrong
Old May 7, 2015 | 09:05 AM
84oldshurst's Avatar
I have a 1984 hurst olds, the tachometer is the stock rally cluster pack tachometer and the RPMs are reading wrong, how would I go about fixing this? I've heard about soldering a switch in the back of the cluster somewhere.... The gauge reads about 1500 rpm at idle. And I know my idle speed is not that high. This is my first post here, thanks for any help!
Old May 7, 2015 | 10:25 AM
oldsmobiledave's Avatar
Suggestion
If it is not a show car remove the tach and install an aftermarket one. Problem solved.
If it is important to maintain the stock appearance try swapping in another used OEM tach and see if it also reads high.
Old May 7, 2015 | 10:40 AM
pavemobile's Avatar
pavemobile
If you remove the instrument cluster you will/should see an orange colored adapter (small) that plugs into a socket on the back tach side. These were notorious for coming loose and making the tach read approx. double. You can fiddle with the adapter or bend a wire and solder it on the 2 small metal tabs. Here is a link to view...not in color but should provide some good info. Used this fix a LONG time ago and all is still well with mine.
http://tech.oldsgmail.com/eint_tach_fix.php
Old May 7, 2015 | 12:15 PM
----wow thank you! That's exactly what I needed!
Old May 7, 2015 | 12:16 PM
Great suggestion, but I do want to retain some of the OEM parts on the car, as I am restoring it little by little, although it is far from show quality, thank you again for your suggestion!
HurstLightning84
Aug 16, 2012 04:58 PM
at3reg98
Apr 17, 2012 10:36 AM
ACID64
Sep 7, 2011 11:16 AM
MN71W30
May 25, 2009 04:07 AM
