1984 Delta 88 brake lights
Old Aug 7, 2019 | 04:46 PM
Rogermartinez's Avatar
I have a two door 84 Delta 88. The rear lights are red and yellow. When i press the brake they both come on. Is this normal or do I have a short. The yellow lights also turn on and off while i have my turn signals on and that is Normal. But i don't believe the yellow and red brake lights should come on together when I press the brake. Does anyone know?
Old Aug 8, 2019 | 08:21 AM
Look at the bottom lefthand corner of your fuse box. There should be a green connector with a white wire plugged into the fuse box at that location. Pull it out and the amber lights will no longer illuminate when you step on the brakes. This jumper is designed for use on cars that have the all red tail lights. Someone apparently plugged it in.
Old Aug 8, 2019 | 10:39 AM
Joe padavano
Thank you very much Joe, it worked i appreciate the help.
Old Aug 8, 2019 | 12:15 PM
jaunty75's Avatar
Regardless of how the taillights work, that is one beautiful car. How many miles on it?
Old Aug 8, 2019 | 12:19 PM
Thanks its got 85k miles
Old Aug 8, 2019 | 12:25 PM
jaunty75's Avatar
Very nice.
Old Aug 8, 2019 | 01:44 PM
Old Mar 15, 2021 | 10:15 AM
EsoWuhn's Avatar
i know this is an old post, but i have these tail lights and am having the same issue in an 80 Delta 88. Would this be the same for me as well, or would I have to replace my connectors at the actual housing? I am currently looking at my fuse box (under the driver side dash), and don’t see that connector..
Old Mar 15, 2021 | 10:24 AM
I believe it should. You may have to check each wire that is plugged in with a jumper to see which one it is.
Old Mar 15, 2021 | 10:31 AM
EsoWuhn's Avatar
I see the white relay, but I dont see a green connector...sorry to be that guy. lol
Old Mar 16, 2021 | 10:58 AM
Old Mar 16, 2021 | 12:01 PM
EsoWuhn's Avatar
Looking at the photos of my fuse block side by side with this diagram, i dont have that connector plugged in. I did notice the turn signal and brake light connectors have two contacts; so would those have to be changed?
73aussie455
Sep 23, 2014 04:10 AM
danimal442
May 2, 2014 07:19 PM
4424me
Nov 23, 2011 12:38 AM
whojohnjones
Mar 11, 2011 04:53 PM
frank24
May 26, 2007 07:26 PM
