1979 Olds Regency 98 Trunk light not working
Old March 31st, 2013, 10:28 PM
heritageadam's Avatar
I'm having trouble figuring out why the trunk light in my 1979 Olds Regency 98 is not working. My voltage tester lights up when I touch it to inside where the light bulb sticks in, but not on the part in the middle which looks like where it actually touches the bottom of the bulb. When I put the bulb in it does not light up.
Thinking it was a problem with the fixture, I pulled the part out of my identical parts car (fixture and about 6 feet of cord which then plugs in). Same thing with that wire/fixture combo. Tried 3 different bulbs in both fixtures.
I've got + voltage where the wire plugs in to the left rear part of the trunk, as well as + voltage inside the where you stick the bulb in as listed above.
What am I missing here? What makes the light turn on when trunk open/off when its shut?
Thanks.
heritageadam is offline
Old April 1st, 2013, 05:18 AM
jcdynamic88's Avatar
trunk light
did you check for ground at the socket? you need a ground as much as you need power.i believe this uses a mercury switch that completes ground when you open the trunk.ive had cars that required the parking lights on for the hood or trunk light and some that didn't(I think older models)jc
jcdynamic88 is offline
Old April 2nd, 2013, 08:12 PM
radioburningchrome's Avatar
X2 on the ground.
My 1980 Cutlass trunk light works all the time, my 1965 88 needed the parking lights to be on.
radioburningchrome is offline
Old April 2nd, 2013, 10:56 PM
Redog's Avatar
Originally Posted by radioburningchrome
X2 on the ground.
I agree on the ground, and my Delta's trunk light works all the time, but the underhood light, parking lights have to be on
Redog is offline
Old April 6th, 2013, 08:10 PM
This is probably an incredibly stupid question but how do I figure that out? (ground) There is only one wire with the power going to the fixture. The outside of the fixture is metal & screws into the trunk. My parts car (same make/model/year) had the same thing - 1 wire going to it. The light under the hood looks the same but works (agree that the parking lights have to be on for the hood light to work). Can't get trunk light to work with or without parking light on.
Is there a mercury switch in the fixture?
Old April 7th, 2013, 05:25 AM
Lansing built
1970cs's Avatar
You mentioned that you had a test light that illuminated! Run a extra wire to the same grouding surface that you used to get a light (known good ground)
and see if that flies.
The deck lid is what is providing the ground so touch the screw and or outside of the socket with improvised ground circuit. I believe that you are correct that it runs off a mecury switch.
Pat
1970cs is offline
Old April 14th, 2013, 05:25 PM
Thanks for the input, I was able to figure it out. The original fixture in my car wasn't working, as well as a poor ground. I replaced it with the one from my parts car & improved the way it is grounded. Works great & shuts off as the trunk is half closed, like it should. Thanks again for the help.
heritageadam
Body work
April 25th, 2015 09:54 PM
Seff
April 28th, 2013 09:57 PM
Oldsmobilliam
December 1st, 2009 05:56 AM
nelsontj
September 19th, 2009 04:24 PM
heritageadam
Cars Wanted
January 30th, 2009 08:20 PM
Quick Reply: 1979 Olds Regency 98 Trunk light not working
