1975 delta 88 converible top stuck
Old Aug 2, 2015 | 06:30 AM
BKras's Avatar
Can someone point me to where the fuse might be? Top stuck halfway up
Old Aug 2, 2015 | 07:42 AM
Is the motor turning, or trying to turn?
There is no fuse. There is a circuit breaker in the fuse block.
The usual failure mode is overheating of the central terminal of the poorly-designed specialty relay that makes it all work, causing the plastic that holds the terminal to melt, and the terminal to move out of alignment.
Welcome to ClassicOlds.
Old Aug 2, 2015 | 07:55 AM
BKras's Avatar
I can hear a click in the back by the top when I try an engage it. That about it
Old Aug 2, 2015 | 08:02 AM
Probably the relay.
It's fair to check the breaker, but you may need to do this.
Old Aug 2, 2015 | 08:05 AM
BKras's Avatar
Eric - much appreciated.....
Old Aug 2, 2015 | 08:44 AM
Also, if you're stuck right NOW, you can (carefully - the plastic gets brittle) unscrew the two drive cables from the two gear mechanisms, located on either side, just inside the top well, behind the rear seat, and carefully raise or lower the top by standing on the back seat, grasping the header bow, and using your back. It's a tough lift because of the angle, but you can put the top up and down this way in a pinch.
Old Aug 2, 2015 | 09:03 AM
BKras's Avatar
Think I mY be heading in that direction. Where is fuse for power windows? Don't see it among the fuses under driver side. Was told it may be in the back?
Old Aug 2, 2015 | 09:22 AM
The power windows should be controlled by the same breaker on the fuse block, if I recall.
You DO have a Chassis Service Manual and a Fisher Body Manual, don't you?
if not, keep an eye on eBay, '75 will be cheap (my '73 CSM was $8, shipped).
Don't buy a CD or a scanned copy - quality will be crappy, especially on the wiring diagrams.
crystal59
Dec 13, 2024 06:38 PM
Timmy Beers
Feb 18, 2013 02:40 PM
1970 F85Poat
Aug 19, 2011 08:15 PM
dyonich
Apr 24, 2011 10:35 AM
dc2x4drvr
Feb 7, 2011 08:20 AM
