1974 Delta vert wiring harness
Old Mar 22, 2011 | 12:59 PM
delta254's Avatar
Is there somewere to buy a full wiring harness for my 74 delta mine is there but my mechnic said if i can try and find a new one if not he can work with whats theres also were can i get wiring diagrams for it as well please thanx.
Old Mar 22, 2011 | 01:47 PM
I doubt you can get a new one for a Delta, as it's just not that popular a car.
More to the point, do you really want to spend an extra $500?
The original is probably fine, but will have more resistance at the connections than it used to. The only place I have seen this as a problem has been in the power to the top motor and the trunk release - the original wiring just can't quite get enough juice to them. Try the top, and the lights dim and the relay clicks, but no action. Touch a heavy hot wire to the terminals, and it wings right over. I'm running an 8ga hot wire back to the top motor and replacing the original relay with a pair of modern weatherproof relays, and using the top switch to trip the relays, instead of handling the full current load (and, yes, I did disassemble and clean the top switch, and it didn't do the trick).
So, if your harness has any really bad problems, I'd say get one from a junkyard, otherwise, what you've got is probably good enough.
Old Mar 22, 2011 | 02:59 PM
delta254's Avatar
OK because theres no power at all inside he said he was going to clean the conectors at the firewall to see if that does anything... thank you again
Old Mar 22, 2011 | 03:45 PM
You need to figure out where you DO have power, and then where you DON'T, and find the place(s) in the middle where the problem(s) is(are).
"Inside / Outside" will not help.
Old Mar 22, 2011 | 03:50 PM
jaunty75's Avatar
Originally Posted by delta254
Iwere can i get wiring diagrams for it as well
Full color wiring diagrams are in the '74 Oldsmobile Chassis Service Manual. These pop up all the time on ebay.
Here's one for sale right now for a very good price.
http://cgi.ebay.com/ebaymotors/1974-...item483f98d298
Old Mar 22, 2011 | 04:29 PM
I paid $8.00 for mine.
Old Mar 23, 2011 | 06:34 AM
delta254's Avatar
oK ill look into this weekend.
Mtorrisi
Mar 17, 2013 04:21 PM
halfmoontrail
Mar 17, 2013 10:28 AM
ent72olds
Dec 3, 2012 07:28 AM
widowmaker1201
Dec 2, 2012 01:27 PM
delta254
Apr 1, 2011 02:57 PM
